I burn onto 80 minute discs... in addition to the clip, I'll have a 5 second intro clip and a set of chapters throughout the clip.
I know the VCD files and the chapter's information all take up some space on the disc... so how much time does that leave for me to put the video clip on there? If I have an 80 minute clip... how much of that clip will I have to erase to make it fit on the 80 minute disc?
Most 80min discs in reality hold a few seconds less than 80min. For this example, let us say that the CD holds 79:57.
Now, your intro clip is 5 seconds long, and if it is in its own track, there'll be a 2 second pre gap as well. (7 seconds total).
The minimum size of the first logical track (where stuff like menus are placed) is 6 seconds. For each additional menu screen, they take up 2 seconds of space. If we include the CD-i application as well, that takes up ~10 s. So, let's be conservative and say that the first logical track takes up 20s (CD-i app + several menu screens).
Finally, on the track of your main movie clip, there will be a 2 second pregap as well.
Thus:
79:57 - 00:07 - 00:20 - 00:02
= 79:28
However, if your CD burner is capable of overburning, you can usually overburn safely by up to a minute on most media...
Regards.
Michael Tam
w: Morsels of Evidence -
I have it on good authority that you can overburn to 83min 59sec on a 80 min CD !
No.
The degree to which you can overburn depends both on the batch and brand of the media, and on your burner.
It is actually very unlikely that you can overburn to 83:59 safely on standard 80min media most of the time.
Usually, you can get about 2 minutes worth. 1 minute is almost assured which was why I quoted it before.
Regards.
Michael Tam
Authoring oversized DVD, then shrink to fit on a disc?
By adamberkey in forum Authoring (DVD)Replies: 1Last Post: 27th Apr 2012, 23:39 -
what do i do to make a dvd movie small enough to fit in one disc?
By polka in forum Authoring (DVD)Replies: 3Last Post: 24th Mar 2012, 01:53 -
How to shrink a 50GB-BLURAY-movie to fit on a 25GB-BLURAY disc ?
By kulmagen in forum DVD RippingReplies: 31Last Post: 1st Feb 2012, 13:39 -
how many MB equal GB/ how many episodes can i fit on disc?
By janeydoll in forum Video ConversionReplies: 6Last Post: 21st Oct 2010, 09:20 -
DVD file too large to burn to disc..how can I make it fit?
By Natalie88 in forum Newbie / General discussionsReplies: 4Last Post: 18th May 2010, 08:14
