Until recently, I had been using DVD Shrink for all my DVD9 to DVD5 backups, and was satisfied. However, on reading excellent reviews on DVD Rebuilder with CCE, I decided to give it a try. The Phase I (Prepare) in rebuilder completes in about 10-12mins. However, each time when I click on the Encode button, the encoding process completes in just 0 or 1 minute. Could someone please point out where I'm going wrong? I have correctly entered the address to CCE in the Rebuilder Setup. Below is the status log from Rebuilder.
[17:20:08] Phase I, PREPARATION started.
- "Steal Space from Extras" mode is enabled.
- VTS_03: 1,832,295 sectors.
-- Scanning and writing .D2V file
-- Processed 121,643 frames.
-- Building .AVS and .ECL files
- VTS_04: 1,742,618 sectors.
-- Processed 115,979 frames.
- VTS_06: 70,405 sectors.
-- Processed 4,898 frames.
- VTS_07: 63,341 sectors.
-- Processed 4,413 frames.
- VTS_08: 56,686 sectors.
-- Processed 3,949 frames.
- Reduction Level for DVD-5: 46.8%
- Overall Bitrate : 2,611Kbs
- Space for Video : 3,198,812KB
- Movie improvement from extra reduction = 34.7%
- HIGH/LOW/AVERAGE Cell Bitrates: 3,538/1,588/2,611 Kbs
[17:36:30] Phase I, PREPARATION completed in 16 minutes.
[17:36:54] Phase II ENCODING started
- Creating M2V for VTS_03 segment 00
- Creating M2V for VTS_03 segment 01
- Creating M2V for VTS_03 segment 02
- Creating M2V for VTS_03 segment 03
- Creating M2V for VTS_03 segment 04
- Creating M2V for VTS_03 segment 05
- Creating M2V for VTS_03 segment 06
- Creating M2V for VTS_03 segment 07
- Creating M2V for VTS_03 segment 08
- Creating M2V for VTS_03 segment 09
- Creating M2V for VTS_03 segment 10
- Creating M2V for VTS_03 segment 11
- Creating M2V for VTS_03 segment 12
- Creating M2V for VTS_03 segment 13
- Creating M2V for VTS_04 segment 00
- Creating M2V for VTS_04 segment 01
- Creating M2V for VTS_04 segment 02
- Creating M2V for VTS_04 segment 03
- Creating M2V for VTS_04 segment 04
- Creating M2V for VTS_04 segment 05
- Creating M2V for VTS_04 segment 06
- Creating M2V for VTS_04 segment 07
- Creating M2V for VTS_04 segment 08
- Creating M2V for VTS_04 segment 09
- Creating M2V for VTS_04 segment 10
- Creating M2V for VTS_04 segment 11
- Creating M2V for VTS_04 segment 12
- Creating M2V for VTS_06 segment 00
- Creating M2V for VTS_07 segment 00
- Creating M2V for VTS_08 segment 00
[17:37:00] Phase II ENCODING completed in 0 minutes.
Thanks in advance!
Originally Posted by b_n83
https://www.videohelp.com/forum/viewtopic.php?t=225548You stop me again whilst I'm walking and I'll cut your fv<king Jacob's off. -
It worked!! Thank you so much. One more question...If I use eclCCE.exe, will it create a watermark in the final video file?
eclcce uses CCE that will create the watermark (if trial version)
bd rebuilder encoding options question
By kronick in forum Blu-ray RippingReplies: 0Last Post: 3rd Jul 2011, 11:21 -
BD Rebuilder stops encoding
By pepegot1 in forum Authoring (Blu-ray)Replies: 2Last Post: 25th Jun 2011, 10:01 -
Bd Rebuilder Failing on Encoding
By Westie69 in forum Blu-ray RippingReplies: 4Last Post: 31st Mar 2011, 02:52 -
bd Rebuilder vc-1 encoding extras aborted
By malevolo in forum Authoring (Blu-ray)Replies: 5Last Post: 27th Apr 2010, 21:46 -
BD-Rebuilder has Error in encoding audio
By teedster in forum Blu-ray RippingReplies: 2Last Post: 14th Oct 2009, 09:07
