  1. I Have Copied some old films onto Dvd using my Panasonic E50 I would like to copy them/Backup
    I have used Nero 6, Alcohol. Roxio DVD, DeCyrpter all to no avail. The Dvd Player Reconises The Disc But Will Not Play Them
    Clone Does Not Recognise the original disc so cant use that programme.
    Has any one any idea.s
    Please
    Redfoot
  2. Are those dvd-r or dvdram? did you finalize your dvd-r disk otherwise it won't play on any player but the panasonic can see it & play it.
  3. Thanks For replying
    They are dvd-r disks and yes they are finalized.
    the original disks play on all the dvd players in the house but once copied the copy will not play on any. the disc is definately written on and contains the exact amount of info as the original copy
    Neil
