I have authored a couple of discs with ifo edit and I have noticed that although they play fine, you cannot fast forward or rewind the discs on certain DVD players. If you try to fastforward the disc gets stuck and starts to pixellate as if its a bad disc the only option is to play it again from the beginning. If you let it run through it plays the whole movie perfectly. However on another DVD player I have I can FF and REV the movie. Anyone else come across this problem.
This problem seems to come up when you encode your video with TMPGEnc:
https://forum.videohelp.com/viewtopic.php?p=1524983
https://forum.videohelp.com/viewtopic.php?t=281894
https://forum.videohelp.com/viewtopic.php?t=200639
But seeing as you can play it fine on another DVD player, your problem might be something different. -
Wow, nearly 2 years old this one
LOL... just thought it'd help out anyone searching through the forums... like me :P
Can IFO-Edit merge files?
By Djard in forum Newbie / General discussionsReplies: 3Last Post: 15th Aug 2011, 11:50 -
trying to edit dvd get VTS_18_0.IFO contains bogus data error, FIX?
By Denvers Dawgs in forum Authoring (DVD)Replies: 6Last Post: 2nd Apr 2011, 17:45 -
Extreme frustration: PAL to NTSC, using IFO Edit
By gabelogan99 in forum Authoring (DVD)Replies: 4Last Post: 22nd Jan 2011, 15:02 -
Can I edit video_ts.ifo to link missing vobs to DVD?
By Srivas in forum Authoring (DVD)Replies: 1Last Post: 21st Jun 2008, 11:39 -
using ifo edit
By thecrock in forum Newbie / General discussionsReplies: 1Last Post: 29th May 2007, 07:19
