  1. I want to convert two divxs to DVD so that the end MPGs both fit on one DVD. Now I record four hours on my DVD recorder all the time so I obviously know 4 hour plus DVDs are possible. But when I convert with TMPGEnc it only lets me bring the file size down so much, usually 60% or so of what a DVD can hold. Am I missing something or should I move to a different program.
    As always, thanks a bunch. I just turned my brother onto the VCDhelp community and he's lovin it too!
  2. Member flaninacupboard's Avatar
    Aug 2001
    Northants, England
    can the wizard, it's very restrictive. tell me how many minutes each file is, and post gspot info if you can.
  3. are you useing the wizard? if so don't. create your own template then you won't be restricted.
    How Big A Boy Are Ya?
  4. As the others said, skip the wizard and set the beitrate manually. Use a bitrate calculator such as the one Here
