Right, to my previous post about audio delay, i managed to fix the out of sync part within the video, so now its all fine and looks as near good as it can be.......but now i come up with another problem, when i burned it to a dvd disc and played it on my dvd player, the audio sync seems to happen again just after a part in the video where it seems to stutter.........but this did not happen when i viewed it in powerdvd, i burned the copy 3 times and it done the same at exactly the same part....... Now is this because its possibly a bad frame ? but if that was the case, then why didnt it happen when i played it back on my computer ? im confused with this oneso any help would be much appriciated !! thanx
Results 1 to 13 of 13
What bitrate did you encode with?
My guess is that it may have been too high.
This isn't the only possible reason for the symptoms you describe, but it is the first thing I would check.
Your player may not be able to read enough data off the disk before the buffer runs out.
Arky ;o) -
thanx, found it.......below are the details of the movie.......
Player Information :
Player Region Code : Not Specided
Current Focus Drive : F:
Title Region Code : Not Available
Display Information :
Video Mode : Bob
Display Mode : DirectDraw
FourCC Code : YUY2
Surface Type : Overlay
Video Attribute :
Video compression mode : MPEG-2
TV system : unknown = 2
Aspect Ratio : 4:3
Display Mode : reserved
Source picture resolution : unknown = 4
Frame Rate : 25.00
Source picture letterboxed : Not letterboxed
Bit Rate : 2.48Mbps
Audio Attribute :
Audio Coding mode : MPEG-1 or MPEG-2 without extension bitstream
Sampling Rate : 48kHz
Audio application mode : Not specified
Number of Audio channels : 6
Bit Rate : 192.00 Kbps
Number of Audio streams : 1
SubPic Attribute : Not Available
Hardware Information :
3DNow! Technology : Not Detected
Enhanced 3DNow! Technology : Not Detected
IA MMX Technology : In Use
IA Streaming SIMD Extensions : In Use
Video Accelerator : Not Detected
Multispeakers Audio Device : Not Detected
S/PDIF Output Device : Not Detected
hope this helps -
3 things in the above information worth a mention...
Bit Rate : 2.48Mbps
This is a bit low for DVD, but shouldn't cause any problems...
192 kbps divided by 6 channels = 32 Kbps per channel, which is BAD, the bitrate needs to be at least 384 Kbps
Knowing this would be useful... 8) -
ummm if im correct the picture resolution is 480 x 576 ? if thats wot you mean by that ? so the bitrate is way to low at 192 ?
Yes, the audio bitrate is too low for 6 channels, as for 480x576?, that isn't a compilant DVD resolution, if it works in your stand-alone player, then thats purely by chance... For PAL use either 720x576 (MPEG2), 704x576(MPEG2), 352x576(MPEG2) or 352x288(MPEG1 at 1700kbps).Originally Posted by Joef2k2
Just to clarify, are you burning to CDR's or DVD's -
so if it works on mine? thats not to say that it will work on all other DVD players ? it also works on my PS2 aswell. and i am burning DVD's not CDR !! when u say its not a complaint resolution ? how do i go about changing that and will i lose any quality ? and as for the sound ? would u suggest i change the bit rate then ? and this may solve the loss of sync once burned to a disc?
1) Weird Problem
2) Help!
3) Help, Urgent!!
4) Out of Sync on DVD but not on computer
Which of the above is a good subject line? (for the answer see this forums faq)
presto, your post helps HOW?
I think you had better start from the begining, as i didn't see your previous post.... -
lol i was actually going to say the same myself but didnt think ide be that nasty........ atleast people with more knowledge then me about the problem are trying to help or give me solutions........then u get presto who decides to take the piss.........if you aint got nothing to say then please dont reply back........ people that do try help, i appreciate it
If you don't understand my post please read the FAQ in regards to subject lines.
Weird, very weird thing demuxing a DVD
By jairovital in forum EditingReplies: 17Last Post: 22nd Oct 2010, 18:31 -
Weird Mouse?
By fairytale00 in forum ComputerReplies: 1Last Post: 7th Jun 2010, 02:07 -
Weird Folder
By mn072065 in forum ComputerReplies: 7Last Post: 28th May 2008, 10:34 -
Weird Audio
By Thr0ttleman in forum Video Streaming DownloadingReplies: 8Last Post: 4th Apr 2008, 05:57 -
colours are weird?
By bennyboyt in forum Newbie / General discussionsReplies: 5Last Post: 23rd Dec 2007, 19:47
