Right off I'm as newbie as newbie gets so I hope this is just a simple newbie error. I just exported a project, about 120 min worth with adobe premiere 6.5 (Adobe mpeg encoder). After a 12-13 hour wait I found two files on my hard drive. One with just video and the other with just audio, where did I go wrong? I checked my settings and everything seems good to go!
thank you for any help!
This is normal. The export settings were set to demux the files.
You could have set the export setting so that the files would have been muxed (or merged) into 1 mpeg file that could play with any player.
Note that you should play each of the files with any player.
What do you want to do with it?
- You can import the 2 fiels in an authoring software,
- you can mux the 2 files with TMPGEnc.
- You can play with your settings and try to learn how to export 1 muxed file.
Have fun.
Adobe Premiere export same as original file?
By kray in forum Newbie / General discussionsReplies: 13Last Post: 9th Sep 2012, 01:05 -
is there anyway to export from Adobe After Effects CS5 to H.264? or other?
By Onceler2 in forum Newbie / General discussionsReplies: 3Last Post: 23rd Nov 2011, 16:59 -
Best export settings in Adobe Premiere CS4
By Polesch in forum Newbie / General discussionsReplies: 5Last Post: 5th Apr 2010, 18:45 -
Adobe Premiere Pro: I used DV footage and Photoshop stills - how to export?
By neckneck in forum EditingReplies: 12Last Post: 20th Dec 2009, 16:29 -
m2ts and ps3 issue/vegas export options aarrrggghhhh
By simoupnorth in forum Video ConversionReplies: 5Last Post: 28th Aug 2009, 01:26
