I've always used instantcopy when back-up my dvd's, until my friend introduced me to CCE. He says this is the best back-up program ever.
He says that he can take a 9gig dvd, and back it up onto a single dvd without touching the original film, but downsamples the extras.
He kept mentioning something about CCE and the number of passes. Default is 1? but he uses 6 for best quality he says. He says 4 passes is not enough, but 6 is great. What the hell do these 'passes' mean?
Is there a 'dummy' website to explain all this? I'd like to understand why this method is the best?
for one -- it is a 2000$ program ...
for another -- your friend doesnt know what he is talking about"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
4 passes? This might make a difference if you're cramming a 120 min movie onto 2 CDRs, but for DVD encoding you shouldn't need more than 2 passes (.VAF creation and main encode).
Basically, 2 Passes would mean that CCE would first scan the movie and create a .VAF file to tell it where all the "busy" parts are, so when it comes to encoding, it can allocate more bitrate to those areas where there are more action scenes, this avoids "blockiness" that can appear during action scenes. -
The basic version costs $58
You stop me again whilst I'm walking and I'll cut your fv<king Jacob's off. -
Originally Posted by tompika"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
thats true
I would just like to know what the whole purpose of this 'passing' stuff means?
What is it??
CCE vs ConvertXtoDVD
By ranosb in forum Video ConversionReplies: 23Last Post: 5th May 2009, 20:14 -
CCE OPV
By name123 in forum Newbie / General discussionsReplies: 2Last Post: 7th Jan 2008, 12:03 -
best software for cce sp
By zookeeper525 in forum DVD RippingReplies: 12Last Post: 25th Dec 2007, 14:41 -
CCE-SP2
By Belfour in forum DVD RippingReplies: 10Last Post: 29th Sep 2007, 19:47 -
CCE VS DivX
By SteveF22 in forum Authoring (DVD)Replies: 9Last Post: 25th Aug 2007, 20:13
