Ok so i Converted the a Video
From PAL to NTSC ( Worked Fine )
Then i use TMPEGnc DVD Author to make menus and all ( Worked fine )
and it creates VOB file and all the other files for the DVD
Ok now i burn the DVD ( Worked Fine )
Put the DVD in my stand alone DVD player
DVD starts but now the menu is too big for the screen
it sorta leaks on each side of the screen ( get it )
What did i do wrong ???
Here are the specs for the video when i finished converting it
From PAL to NTSC
Video: MPEG-2, 720x480, 29.97 fps, (4:3) NTSC, 7412 kbps
Audio: MPEG-1, Audio Layer-2, 48000 kz Stereo, 384 kbps
Thanks for any help
Were you aware of the "TV Safe Area"? Because of overscan some parts of the picture may disappear, depending on the TV/Monitor. Tmpgenc DVD Author has this TV safe area to guarantee that just such a thing wont happen...(note the dotted line around the menu area), enable this by right-click/options (i think), just make sure your image appears within this area and things should be ok
That's a standard issue with TV called overscan. Normally, it's considered that about 5% of the picture from each edge won't be visible on the TV screen, and you shouldn't put any text within 10% from each edge to prevent distortion. TDA is flexible enough to allow resizing of the menu.
Ahhhhh !!! Thanks dudeenable this by right-click/options (i think)
That worked
menu problem in TMPGEnc DVD Author 3
By sanduul in forum Authoring (DVD)Replies: 13Last Post: 23rd Oct 2007, 20:20 -
TMPGEnc DVD Author 1.6 thumbnail menu issue
By Bix in forum Authoring (DVD)Replies: 0Last Post: 3rd Oct 2007, 11:00 -
TMPGEnc DVD Author 3 (MENU PROBLEM)
By jaffacaique in forum Authoring (DVD)Replies: 9Last Post: 18th Sep 2007, 20:43 -
TmpgEnc DVD Author 3 - Question About Menu Music
By heyjjjaded in forum Authoring (DVD)Replies: 10Last Post: 30th Jul 2007, 14:16 -
Menu troubleshoot using Tmpgenc Dvd Author
By tekka06 in forum Authoring (DVD)Replies: 8Last Post: 4th Jul 2007, 04:53
