I have an ATI AIW 9800 PRO but i get light and dark "bands" which travel down the screen I though it was the cables i was using so i bought some monster cable thx certifed cables but that didnt cure the problem can someone tell me what it is and how to fix it???
Sounds like macrovision? Are you trying to capture a commercial VHS?
no just capturing tv shows off digitial cable oh i was wrong bands travel up the screen usually hard to see untill you know what your looking for but now i can spot them all the time.
So... could it just be a playback issue? are you playing through some software or is this a finished dvd?
Maybe it's just the interlacing showing up in your software...
Also.. what format are you capping? -
Sent you the PM.
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 02:52 -
next to the 8mm tape whats the best way to store "raw" captured f
By st711 in forum MediaReplies: 2Last Post: 25th Dec 2009, 23:58 -
All captured video has "Corrupt Header"
By raihnman in forum Capturing and VCRReplies: 2Last Post: 8th Mar 2009, 16:52 -
Ripping "Shine A Light" problems
By robertazimmerman in forum DVD RippingReplies: 7Last Post: 11th Aug 2008, 18:50 -
Anyone see "The Dark Knight" in a Theatre with DLP?
By peggypwr1 in forum Newbie / General discussionsReplies: 3Last Post: 31st Jul 2008, 00:45
