Hi!
Sorry, but my english is a little poor!
Yesterday I 've recived a new MIRO DC10+.
I work with Windows Me.
The instalation of Miro was fine, but I can't capture. when I try it, the computer crash and I must restart my computer again.
I think that the problem is the compatibility with the motherboard.
I have:
AMD athlon 1333
Motherboard ASUS ATA266
HD. 30 Gb 5400 rpm (OS. WIN. ME)
HD. 40 Gb 7200 rpm for capture
videocard with GEFORCE 2 MX (64 Mb)
Do anyone run with this combination? Know anyone what can i do?
Thanks for your attention.
Miquel
Hi,
best thing to do is to delete WinMe and go back to Win98. Hade the same problems (and many more) with WinMe.
Regards
RoKo -
Hi roko!
Using the card support WIN. Me. Have you resolved the same problem installing Win 98 SE?
Which is your machine?
Thanks!+ -
...I've used the board before, on W98SE, emachines PC (Celeron 500). No problems.
Have you checked IRQ conflicts? This card does not allow IRQ 'sharing', other than with PCI Steering crap. And recommendation was that no other programs running while you're using the card.
Hi jtor!
Are you using the ASUS A7A266 and the DC10+ in Win. Me?
I haven't tested IRQ conflicts. I'll try it.
Thanks. -
sorry, I don't really know what motherboard the emachines PC is using. But I'm running W98SE on it.
I strongly suggest that you check Pinnacle's webboard. You'll see a lot of problems posted there, and you'll surely learn a lot. -
Hi Jtor!!
I did it, yesterday I wrote to Asus and I was reading the pinnacle webboard.
Miro DC10 /DC10+ and fedora
By bmw524 in forum LinuxReplies: 2Last Post: 14th Nov 2008, 15:54 -
Pinnacle AV/DV2 or DC10+B miserable performance
By cybertheque in forum Capturing and VCRReplies: 1Last Post: 17th Sep 2008, 22:44 -
Miro DC10 + Fedora core 8
By bmw524 in forum LinuxReplies: 5Last Post: 7th Jul 2008, 08:28 -
Pinnacle DC10 Plus on Windows XP
By Paulsa in forum Capturing and VCRReplies: 0Last Post: 3rd Apr 2008, 11:02 -
DC10 Plus Capture
By jackylhome in forum Capturing and VCRReplies: 1Last Post: 30th May 2007, 18:12
