I am using ULEAD DVD Workshop 2.1
My HD is in NTFS format
It transfers the entire 60 minute video to the computer, but does it in 4GB sections (3 of them total) Why?
I use WinDV to copy my files. It actually will split the files into sizes based upon where I had paused in recordings. Sometimes I will have a 6gig file and then the next file is 100megs. I have not recorded a full tape straight through yet. Don't know if this helps you at all, but if it does, even a bit, then great.
Ulead splits the file around 19 min of capture, unless you uncheck that option.
How to put files bigger then 4gb on FAT32 hdd
By WinSpecToR in forum ComputerReplies: 14Last Post: 14th Jun 2010, 07:22 -
Problem Extracting files over 4gb
By PSS2 in forum Software PlayingReplies: 5Last Post: 4th Apr 2010, 21:27 -
Is my PC up to capturing from my camcorder?
By alhenderson in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 32Last Post: 21st Sep 2009, 03:54 -
Capturing from DV Camcorder
By m baqar in forum Authoring (DVD)Replies: 1Last Post: 21st Apr 2008, 00:16 -
Extraction of raw A/V from AVI container for files >4GB?
By alfonzo in forum Video ConversionReplies: 22Last Post: 11th Sep 2007, 08:18
