hello, can somebody pls help me, I am in the process of adding permanent sub to avi to make it into a vcd.
I tried two method one is virtualdub, was able to add the subtitle but having problm with the compression it turn out 20GB.
the second was Tmpgenc, I heard from someone that tmpgenc can directly add the subtitle, but i wasn't able to do it, I already put directshow into its highest priority but still wont load the subtitle.
frameserve from virtualdub to tmpgenc then.
www.videohelp.com/virtualdubframeserve -
baldrick, thank for the info.
I did follow the instruction in "how to frameserve with virtualdub", btw, how long does it take to frameserve???
from the guides--> "This window should appear, and it should say AVIFile only under Frameclients installed:
Don't Stop it until you have encoded the video."
I tried it twice, once for half a hour, and another for one hour still nothing happen, so click the stop serving. and that for only 350avi!!!
I tried to uninstall virtualdub and then install but still the same.
Need help vlc playr problm..
By u4upendra in forum Software PlayingReplies: 0Last Post: 25th Jun 2011, 21:37 -
Problm with Subtitles in DVD Architact.
By ramrakhio in forum SubtitleReplies: 0Last Post: 26th Sep 2010, 14:35 -
Subtitle Creator - Unable to set Default Subtitle Colors & Default Prof
By blue2 in forum Authoring (DVD)Replies: 2Last Post: 15th Nov 2009, 22:47 -
VirtualDub & VirtualDubMod Error Messages..R & R
By sandman423 in forum EditingReplies: 4Last Post: 18th Oct 2007, 05:30 -
Virtualdub+subtitle help
By Anggie in forum SubtitleReplies: 2Last Post: 19th Aug 2007, 03:35
