Firstly I'm a newbie so appologies if this has been covered before.
I have looked on previous postings to resolve my problem, to no avail.
I have an LG DA 3620 home cinema DVD player, which will not play any of my home movies made with Pinnacle studio 8 and also when rendered to AVI file format and then burned using the latest version of Nero.
I have also tried Sonic My DVD?
I have tried several combinations of media, ie, Lite-on and Ritek and Ridisc disks, both + - and RW.
I wrote to LG to try and resolve my problem and they stated :-
Your unit only plays DVD and certain CDR +- disks and MP3.
What do they mean "DVD".
I thought that the two main standards of DVD were DVD+ and DVD- with type 5 and 9 respectively and 4x or 8x.
I have tried lots of differing combinations of software and disc media to try and sort my problem.
My standalone player ejects the DVD saying "error disc not recognised"
However...... there is a "fly in the ointment" so to speak.
My disks play in my sons cheap and nasty standalone player and also a few of my familys. Also, I was recently loaned a pirate disc to which I DO NOT condone. But....with my current problems I thought I would give it a try and play it.
Its of low quality DVD media, ie AITA DVD-R 4x.
Low and behold the disc plays 100% OK.![]()
Why cant I make a disk with the same type and format that plays?![]()
P.S. the pirate disc was politely returned.![]()
Any help would be greatfully appreciated.
My PC/system build is on my profile and I use ALL upto date programs and drivers etc with all non esential TSR progs shutdown inc anti-virus/ screen/power & monitor disabled with no keyboard strokes and mouse actions at all.
HELPPPPPPP please?
Results 1 to 13 of 13
Is this your DVD Player....
https://www.videohelp.com/dvdplayers.php?DVDnameid=2087&Search=Search&#comments
Possiby one of the people make a post for this machine may have some feedback.
Try downloading several other authoring / burning programs (my favorite is DVD Movie factory)... burn a few DVD's and test 'em out.
If you still have access to that one dvd that worked ... try a DVDInfoPro to determine Original Mfg.... the go by more of those disks.... -
Yep....that's the player.
I'll try the DVDInfoPro and post feedback.
Thanks for the suggestions.
Please keep them comming people please as all help IS appreciated. -
Hi,
I used power DVD and the disk plays 100% OKi n my PC, complete with a complex set of chapters/scene selections etc .
I also used DVDInfoPro to check both the home movie disk and the pirate playable disc and they were all virtually identical, except for the movie lenth.
They were even burned with Ahead Nero.
I also checked the Video_TS folder and there are video files there, but there is no Audio_TS folder on the homemovie disk.
I honestly don't know where to look now.......
help..................
From what I read on this site some DVD players need the AUDIO_TS (notice all caps)folder to be playable. Nero adds this folder when you select the DVD video template.
Hi edlav
Thanks for the reply.
I checked my home movie disk and low and behold, no AUDIO_TS folder.
However, I did use the Nero DVD template to produce the disk........
I'll reburn a copy with this folder included and see what happens.
Thanks for the help.
Cheers. -
What is your source, dv ? avi ?, original dvd ?
What guides are you following ? -
Hi Hardcoreruss.
I imported (via Pinnacle studio 8) from my Pannasonic DV camcorder then authored the result in AVI using Studio 8 as that is what most people tell me to do, then saved the result as an AVI file for Nero Vision express (latest version) to burn.
Hope that helps.....?
So you are using nero to take your avi through to dvd complient files ?
In a nutshell ...............yes.
By the way, thanks for your help
I would have a look at the guides section on the left and convert using different programs. It may be a bit more long winded but the end result would be much better.
I personally would use the following programs (in this order)
virtualdub
tmpgenc
tmpgenc dvd author
nero (to burn only, no converting)
Check out the guides on the left.
how to burn avchd on dvd-r in high definition for BR set top playback?
By masterpug in forum Authoring (Blu-ray)Replies: 32Last Post: 15th Aug 2010, 17:47 -
Looking for compact set-top DVD player
By Djinn987 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 13th Jun 2010, 16:20 -
Ripping To HDD For Media Extender/Set Top Box Playback
By Satchmo in forum DVD RippingReplies: 8Last Post: 18th Feb 2010, 18:25 -
PC drive in set top DVD player?
By wetcamelfood in forum Newbie / General discussionsReplies: 4Last Post: 18th Aug 2009, 15:59 -
Choppy playback on set-top players only...
By Anonymous4374945 in forum Newbie / General discussionsReplies: 1Last Post: 26th Dec 2007, 14:51
