Results 1 to 14 of 14
  1. None of the dvds i have made will play on my standalone dvd player (bush dvd10005/a). They work fine if i play them on my pc or through my ps2. I have tried burning on several types of + and - media but it just won't play. I have some home made dvds that i bought off ebay that play on it fine.
    any ideas?
    Apr 2002
    The State of Frustration
    What procedure(s) have you used to create them? Be specific.
    Hello.
  3. Done it many ways.
    Rip dvd with dvd decrypter
    burnt it with nero 6/dvd lab/copy2dvd and im sure some others i have forgot.
    The funny thing is i have made a test menu, burnt it on a dvd, doesn't work. I then burn the exact same thing to a cd using the mini dvd option in dvd lab and it works fine.
    Monroe, Mi
    sounds to me like your dvd player just doesnt work good with burned media. have you tried dvdrw's?
  5. not tried them, are they likley to be more compatible? Its just strange that the copied dvds i have bought work fine. I have even done a straight copy of one of these dvds (not encrypted) and that doesnt work on my player.
  6. Try to use another DVD burner if possible.
  7. Member flaninacupboard's Avatar
    Aug 2001
    Northants, England
    There's your answer, crap discs. use ritek g04 or taiyo yuden discs.
  8. used about 4 different brands of discs + and -, none of the worked. I have ritek g04 discs and they don't work for me. I don't want to buy another dvd burner and have that not work as well.
  9. Member flaninacupboard's Avatar
    Aug 2001
    Northants, England
    put the discs that -do- work in your dvd drive and run dvdinfopro. that will tell you what dye type is on the discs, so you know what to buy in future.
  10. What info should i take from this? what coating is this dvd
    Media Information
    Disc Regions are 1,2,3,4,5,6,7,8
    Media code/Manufacturer ID PRINCO
    Format Type UDF 1.02
    Volume Name NEW
    Application id
    Implementation id AHEAD Nero
    Recording Date/Time (mm/dd/yyyy) 4/28/2003 10:16:12
    Format Capacity 4.34GB(4.66GB)
    Book Type DVD-R
    Media Type DVD-R
    Media Id Code Speed 1.0x 1385KBps
    Available Write Descriptor CLV 1.0x 1385KBps
    Available Write Descriptor CLV 2.0x 2770KBps
    Available Write Descriptor CLV 4.0x 5540KBps
    Write Strategy Speed 4.0x 5540KBps
    2x Speed OPC beta 0B
    2x Speed OPC power 0F
    2x Write Strategy field 1 11 86 67 80
    2x Write Strategy field 2 88 80 00 00 00 00
    4x Speed OPC beta 01
    4x Speed OPC power 1B
    4x Write Strategy field 1 0B 0E 08 08
    4x Write Strategy field 2 55 09 0F 0B
    4x Write Strategy field 3 C0 88 80 88
    4x Speed OPC beta multi-pulse 00
    4x Speed OPC power multi-pulse 00
    4x Write Strategy field 4 00 00 00 00
    4x Write Strategy field 5 00 00 00 00 00 00
    4x Write Strategy field 6 00 00 00 00 00
    Data area starting sector 30000h
    Data area end sector 22B4FFh
    Linear Density 0.267um/bit
    Track Density 0.74um/track
    Number of Layers 1
  11. Member sacajaweeda's Avatar
    Sep 2003
    Would I lie?
    Maybe it just needs a little oil?
    "There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke
    Jun 2004
    Cyprus
    Is your burner Dual Layer or your original disks are DVD5s? You only mention Decrypter and no reencoding or reauthoring, so I guess you don't edit your vobs in any way. How do you use Nero to burn? Try to create a new DVD video, drag your vobs and ifos in Nero's Video_TS folder and if DVD Video files reallocation fails, it's either your standalone player or your media. I wouldn't blame the burner before excluding everything else.
  13. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Media Information
    Volume Name NEW
    Application id
    That's pretty much all you need. They are PRINCO discs that have been burnt with Nero.
    If in doubt, Google it.
  14. Thanks for all your help guys.
    Updated my drive firmware and now i have working dvds coming out of my ass.
