I flashed the firmware to 110 some time ago and have been happily burning at 8x, Today I saw there was another revision upgrade to be had to 116 so I went for it. I have tried to write some discs with Nero 6 but it will now only write at 4x. Have I dropped a bollock? Can I reverse the process if I have?
carpe diem maņana
You should be able to go back to the older firmware if you kept a copy of it. If you didn't then search around for it. I am sure you will find it.
I tried to load the 1.10 that I used last time but it said it was unable to find the target. When I reset my computer, XP said I had new hardware and reinstalled Pioneer drive. I tried again and this time my computer reinstalled the Compct Flash drive as letter G: insteaed of the Pioneer, The Pioneer has gone to the end of the line as drive Q: What is going on?
carpe diem maņana -
Simply put when you updated the firmware the drive was re-recognized by XP. Unfortunately the drive letter it had before was taken over by the removable media and your pioneer drive was given the next available letter. Not to worry, you can change the drive letters simply by going to administrative tool in the control panel. Then select computer management and on the left side select disc management. Now just reassign drive letters as you please. The only drive you should not do this to is the main boot drive.,
Fazza right click on that lighting thing and then change the letter G to Q and all will work
Cheers. Back to normal. I've revised firmware to 1.13 now and 8x is back. Think I'll leave well alone now!
carpe diem maņana
updating the x264 revision within RipBot?
By shagratt71 in forum Video ConversionReplies: 0Last Post: 14th Dec 2011, 01:08 -
Review this system.... (revision 2.0)
By Engineering in forum ComputerReplies: 14Last Post: 17th Dec 2009, 09:54 -
VideoInspector 2.1.0.116
By Kyle_Katarn in forum Latest Video NewsReplies: 0Last Post: 3rd Jan 2009, 10:13 -
Please, when revision 0.0.9y?
By sepulcrio in forum ffmpegX general discussionReplies: 20Last Post: 29th Jan 2008, 06:55 -
Pioneer DVR-107D mistakes certain DVD+R/DVD-R discs as "blank CD"
By litmus in forum DVD & Blu-ray WritersReplies: 3Last Post: 5th Sep 2007, 13:38
