hi
I want to confirm a load of home videos onto dvd
Currently i have a PCTV card but the picture jumps around
when Im capturing. I believe i need something with a TBC.
So any suggestions as to whether I should get a decent capture
card with TBC (if so which one) ,or a DVD recorder
any suggestions appreciated
thanks
I use a panasonic e30 but you can only get a e55. Use LP mode, push play on vcr, record on the panasonic & thats it. Then when done, create a menu, take s about a minute then finalize disk.
Wont copy macro protected stuff. try buydig.com for prices on the panasonics. -
Many will argue that a good TBC is essential for stabilizing VHS... Many standalones claim they have TBC built in but I'd want to see a sample recording before I dropped the cash on one...
This debate often rages. Each has it advantages and disadvantages. I think the standalones are probably more limited with what you can do with them. Cap cards are more versitile but not a simple "push record" solution...
Users of the Datavideo TBC-1000 seem to be very happy with it.
The price is around $300 USD
Or you buy a DVD Stanalone recorder, or ....
PCTV, you mean pinacle PCTV?
If so, you need to use the btwincap drivers and you forget the tuner of your card that way....
Then, you can capture avi (virtualvcr, virtualdub won't work with your card easy...), encode to mpeg 2, author and burn, or you can capture realtime to mpeg 2 (mainconcept 1.4.2 's built in capture fuction) *IF* you have a 2000Ghs CPU and learn how to set up your hardware and your software at the same time....
(Actually, I can use MC with a duron 1200 and full capture to 1/2 D1 mpeg2 in realtime, but after a lot of trial and error. Most people don't have the patience neither the time for this...) -
I now prefer the stand alone solution, quick and easy and the quality is good enough for me. I still use my PC with editing software and VMagic for creating DVD's from my material shot with my DV camera though.
The Unofficial VMagic Support Site
http://vmagic.unimatrixhub.net -
Panasonic dvd recorders have special filters you can't get on your PC so they make vhs look better than the original. There are a lot of posts here saying that already.
Capturing via capture card or DVD recorder
By mark23 in forum RestorationReplies: 5Last Post: 9th Apr 2012, 12:20 -
Looking for sound card recorder (not Total Recorder)
By jimdagys in forum AudioReplies: 1Last Post: 7th Jan 2011, 20:23 -
Dazzle dvd recorder capture card and a VCR problem
By leeh in forum Capturing and VCRReplies: 5Last Post: 3rd Jul 2008, 14:53 -
dvd recorder or usb tv / video card
By faithzzzz in forum DVD & Blu-ray RecordersReplies: 5Last Post: 13th Sep 2007, 11:09 -
Using Capture/Recoding PCI card - GV-650 Video Capture Card
By Confused Chimp in forum Capturing and VCRReplies: 1Last Post: 6th May 2007, 18:15
