I tried to backup my bone collector dvd. I have always used dvd decryptor and dvd2one then nero.
Well this time I copied the full disk with decryptor..(it is 7.8gigs full movie) so I used dvd2one movie only, and ac3-6.
I burned it and well the movie looks great but all I have is directors commentary on the entire movie...no sound.
I am hoping that someone can tell me what I screwed up so I won't do this again.
I have backed up almost all my collection and never seen this before.
Thanks big time for any pointers
etrin
Usually directors comments are on ac3-2. Which stands for 2 channel. You will need these to hear the directors comments. They usually don't waste space using ac3-6 (Dolby Digital) for this. Hope this helps
well I just went back and did a full dvd backup.
NOW I have no sound in the movie.
BUT I have sound in the menus.
This is the craziest thing I have run across yet.
etrin -
use DVDShrink audio preview so you can see which track to keep
you may be removing streams from the main movie and it now has a 'ghost' stream which is empty and playing on default
you can manually change the 'ghost' stream values using Ifoedit so that no matter what stream is selected by default, it will play a stream that contains audio -
MackemX do you mean the audio selection when you right click on the video ?
It says to right click on video to switch audio streams
Is this correct?
Funny I have seen 2 guides select no audio streams wonder if this works
sparks -
yes, thats right but thats just for preview and nothing else
if you remove the default stream then you would have to manually edit the IFO's to make it play one of the streams you kept -
wulf109 I get confused on the ac3 stuff.
this disk has ac3 5.1
english and french
ac3 2.1
and a lot of others.
I was trying to compress this disk down but still have
a good picture.
So I used dvd2one
I said ok the 2.1 is a lot smaller than the 5.1 so I chose it.
directors commentary (IF I remember correctly)
so I then went in and used dvd2one again and this time I picked the 5.1 sound track english
NO sound in movie...just some sounds in menus
OK so dvd2one full disk...
again no sound....
WAIT 2 channel is directors and 5 channel is NO sound ?
full disk is no sound??????????????
HUH I KNOW I am nube but this made no since to me
I am out of english selections here
I then noticed one thing on the full disk copy with no sound
It has sound in a 1-2 minute quick preview of other movies they have out ...that plays just before the movie.
So I assume that the audio tracks are for the previews and not the movie.
OK which one is the movie ?
so I tried DVDShrink ....just full disk with extened scan
it works fine.
I think I wore out my original LOL
I am going to go into dvdshrink and play the movie now and try to see which one of the sound tracks is with the movie
but this is the first disk I have seen like this and it was very weird.
Chicken Bone
By budwzr in forum Off topicReplies: 10Last Post: 23rd Jan 2012, 10:01 -
what is the 'DSL' file that seems to appear from time to time on DVD's?
By rotuts in forum MacReplies: 6Last Post: 24th Aug 2008, 14:08 -
Problem Using Vider Studio 10 - Start Time After End Time
By jmsrickland in forum Newbie / General discussionsReplies: 0Last Post: 31st Jul 2008, 17:48 -
Movie Collector 5.2 Build 5 problem
By logannsan in forum ComputerReplies: 0Last Post: 3rd Oct 2007, 18:53 -
Have you ever had a broken bone?
By yoda313 in forum PollsReplies: 29Last Post: 1st Sep 2007, 23:22
