I read the following in an article on Tom Hardware Guide: "Making Digital Home Movies, Part 1" and it noted the following:
"Here is an important tip from the professionals about buying Mini-DV tapes: Always buy the same brand of tape. Do NOT use TDK one day, Maxell the next day and then Sony the week after. Different manufacturers use different lubricants on the tape surface. If you mix and match tapes, you can gum up the camcorder recording heads, causing the camcorder to die."
I was curious if anyone else out there stuck with the same brand each time they bought tape. I usually switch based on what's on sale at the time.
Thoughts ???
Look about a third of the way down the page:
http://www.adamwilt.com/Tidbits.htmlHope is the trap the world sets for you every night when you go to sleep and the only reason you have to get up in the morning is the hope that this day, things will get better... But they never do, do they?
cheap mini dv tape playback
By CrippleCreek in forum Portable VideoReplies: 1Last Post: 4th May 2011, 13:51 -
Capture progressive mini-dv tape on interlaced mini-dv cam ?
By alip in forum Capturing and VCRReplies: 4Last Post: 8th Feb 2011, 17:27 -
mini DV tape into computer
By caseyrunning in forum Capturing and VCRReplies: 4Last Post: 24th Apr 2010, 02:42 -
How to Fix My Scrambled Mini DV Tape?
By heydudeitsme in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 9th Apr 2009, 22:01 -
mini-DV tape moisture with Redbull
By manisolo in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 20th May 2008, 20:33
