While trying to encode an AVI (XviD/AC3) movie as DVD, I got the "**ERROR: [mplex] MUX STATUS: Frame data under-runs detected!"-error. However, it produced a file with mpeg-2 video and AC3 audio, that seems to be working fine in mplayer and VLC. The new mpeg movie is complete, i.e. audio and video from begin to end, but only 2.72 GB instead of the expected 4 GB. No VIDEO_TS folder was created. There were temp files created named movie.copy and movie.mpv.
I tried a second encoding with "Decode with Quicktime" off, but this morning the application ‘Progress’ had unexpectedly quit, again after producing a working mpeg file, this time 3.88 GB in size. No (i) output, since the application was no longer running. A VIDEO_TS folder was created this time, but the one file, VTS_01_1.VOB was 0 KB.Originally Posted by little blue (i)
If Progress crashed, possibly your AVI (which seem joined), had some problems. If you kept the AVIs before joining, try to encode them separately (disable 'Decode with Quicktime' and 'Author as DVD'). Then use Sizzle to create the DVD.
DVD authoring failed, advice?
By Elevenius in forum Newbie / General discussionsReplies: 12Last Post: 8th May 2011, 14:06 -
My first attempt to backup a DVD failed...
By Inkognito in forum Newbie / General discussionsReplies: 1Last Post: 8th May 2010, 18:07 -
Converting .flv to DVD ..failed
By oodles in forum Newbie / General discussionsReplies: 4Last Post: 13th Jun 2008, 18:07 -
DVD File Allocation Failed
By Emeraldas in forum Newbie / General discussionsReplies: 8Last Post: 22nd Sep 2007, 08:26 -
1st two DVD-DL recordings failed
By DSSTBUSTER in forum DVD RippingReplies: 28Last Post: 9th May 2007, 01:23
