This question refers to do drag and drop writing (utilize burner like a hard disk/diskette) on DVD RW & DVD RAM ( i am using LG 4082 writer )
which software produces DVD RW that is less prone to error; say I back up 1000 files ( overidding all of them everyday from Hard disk to DVD RW & DVD RAM )
** I think the both the UDF packet writing software below produces problems..so what software suits me best .? ?
1) NERO InCD 4.0 drag-and-drop support
or 2) B’s clip : utilize burner like a hard disk ( drag and drop UDF packet writing software ) to produce DVD
3) any conflict or problems created if I install both Nero 6 and B’s clip, B recorder Gold, and power producer Gold
Sure it does. Told ya, give it up with the packet writing software. Why don't you use normal backup programs; there is even a built-in one in Windows. Try Nero BackItUp, ArcServe, etc.; there are lots of choices to suit your budget.Originally Posted by faithfoo
why not create a folder on your hard drive, drag and drop your files into it. once you have all your files burn a proper discs - packet writing is (in my experience) shit.
(Mp4, AACv2, MKV, Webm, Theora) Drag Drop Convert GUI Update v 1.2.0.0
By richter03 in forum Video ConversionReplies: 11Last Post: 21st Apr 2013, 05:35 -
Drag and Drop Assets
By scoooter1 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 7th May 2011, 04:37 -
AVC H.264 MP4s displayed black by VirtualDub upon drag'n'drop
By bulgom in forum EditingReplies: 22Last Post: 6th Apr 2011, 20:18 -
Drag n Drop Problem
By Jim255 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 29th Mar 2011, 03:26 -
Author tool that allows for drag-n-drop template authoring?
By jlietz in forum Authoring (DVD)Replies: 2Last Post: 16th May 2007, 12:54
