I have a TEAC DV-W58E Burner which came with my Dell computer. I don't know the OEM of this drive. So does anyone know if this drive has the bitsetting feature? If so how can I get the firmware to do this? Any help will be greatly appreciated.
Results 1 to 10 of 10
rpc1.org says it could be a BenQ drive.
If you burn with Nero check if it gives you the option to bitset
otherwise try to bitset with DVDInfo PROYou stop me again whilst I'm walking and I'll cut your fv<king Jacob's off. -
Thanks for the info. I tried using DVDInfo PRO to do this it says "Error, this drive does not support bitsetting" So this could not be a BenQ drive right?
Aha its a dual layer drive.
Then try the LiteOn Bitsetting Tool, it might be a LiteOn
http://www.liteonamericas.com/us/download_utility.htmYou stop me again whilst I'm walking and I'll cut your fv<king Jacob's off. -
I tried that too now. It did not work. It says the drive does not support bit setting. So it's not a LiteOn drive right? Can it be a Nec or pioneer? Any ideas?
There seems to be two versions of the DV-W58E, one supporting DVD+R DL and one older model that doesn't support DVD+R DL.
The drive doesn't look like an OEM Lite-On or NEC. Actually the drive doesn't look like any other OEM drive I know based on how the specs, drive and firmware looks like so if it doesn't support bitsetting out of the box I don't think it's much you can do about it. -
Do you happen to know the OEM of the DV-W58E version that supports dvd + r DL?
No, the hardware of the DL version is probably the same as of the non-DL version as the rest of the specs are identical.
Hey thanks for the info. I just called up dell Tech support and exchanged my Teac DV-W58E drive for a NEC DVD +RW drive which they also offer for dimension 8300. I hope that can do the trick. Is Nec better than Teac? I hope I didn't make a mistake
Hey I just received my New NEC ND-2100A. I installed it today. I noticed on the to side of the Teac DV-W58E drive there was some labels. Some in japanese and the model and serial numbers of the drive. I noticed on the label that had japanese words under them was BENQ technologies. So I guess this drive was a BenQ drive which is also Dual layer upgradable. I don't know why DVDInfoPro said that this drive do not support bitsetting.
Bitsetting compatibility
By davidprosser in forum Authoring (DVD)Replies: 2Last Post: 12th Jan 2011, 13:39 -
Does a Samsung TS-H653N support bitsetting?
By raryke in forum DVD & Blu-ray WritersReplies: 4Last Post: 26th May 2009, 10:54 -
Change bitsetting on DVD Duplicators?
By wetcamelfood in forum Newbie / General discussionsReplies: 7Last Post: 14th Sep 2008, 13:58 -
Enabling Bitsetting on Pioneer DVR 215
By here2rock in forum DVD & Blu-ray WritersReplies: 2Last Post: 16th Aug 2008, 04:29 -
Any Pioneer burners do bitsetting?
By kenmo in forum DVD & Blu-ray WritersReplies: 62Last Post: 7th Jul 2008, 22:33
