Is the AC3 plugin from TMPGEnc Author create an AC3 file that is as compatible or better than using the raw WAV file when authoring a DVD?
I've heard a lot of great things about Sonic Foundry Soft Encode but since it's no longer availabe, is there somewhere or some how to still get a hold of it...drop me a PM if you have to ;]
I've read a lot of raves about Besweet, but then again, I've heard it's not very compatible, not nearly as compatible as just using the HUGE raw WAV file from the AVI.
I want to go AC3 to save space and have the ability to encode at higher bitrates and put longer clips on my DVDs but don't want to sacfrifice compatibillity.
suggestions? FulciLives...help! I know you da man when it comes to the SFSE!
Results 1 to 30 of 44
I use ffmpeggui to encode .wav to .ac3. It's fast, free, and works!!! BeSweet can tend to get a little complicated...but it is free. For ease of use and price you can't go wrong with ffmpeggui. You can convert to other formats also. Its so simple a monkey could use it. The .ac3 streams have always been compatible with every DVD I have made.
Look, let me explain something. I'm not Mr. Lebowski; you're Mr. Lebowski. I'm the Dude. So that's what you call me. That, or Duder. His Dudeness. Or El Duderino, if, you know, you're not into the whole brevity thing-- -
Thanks for your reply but I was specifically avoiding this one b/c of the comment made at the link you supplied:
I need something that is compatible, with a remark like that it doesn't sound to encouraging. -
I must agree...ffmpeggui is great!! Only problem that I seem to have with it is when playing my authored DVDs, the audio seems to be too loud...(no option to attenuate volume on output...) other than that, ffmpeggui works perfectly for me...load almost any source (MPEG, WAV, etc...), and a few minutes later you have a fine AC3 file for use when authoring.Originally Posted by CaseyComb
BeSweet never worked correctly for me...just a thought
mastersmurfie -
Go with Sony Acid Pro 4.....itīs very easy. Load your audio clip, equalize it, regulate the volume, add effects....or leave it untouched and go to file....render and choose AC3. The audio quality is amazing. You wonīt believe you just convert an uncompressed PCM to AC3.
Besides that, itīs a looping software....perfect for menus and stuff.
Works perfect and itīs very easy...the GUI is kinda complicated but donīt let it scare ya....if uīre not going to do some loops or audio processing, just open the audio clip and inmediatly render as AC3.
adiu. -
Anyone else? Specifically on the compatibility of this FREE product...I have to admit, I'm tempted to just go this route but uncofident in it's compatibility. Even though I could just back up my wav's I'd rather have full confidence in what I'm encoding.
Holy pricey stuff batman! That is expensive!!Originally Posted by haznut
Sure, it has a lot of bells and whistles, but for the average user, who just wants to save disc space, free is better...Platform: WindowsŪ 98SE, Me, 2000, or XP
List Price: $499.95
Starting at: $399.96just a thought
mastersmurfie -
Only players I ever saw hate AC3 from Besweet was a Pioneer DV-333 and Pioneer DV-334, players that suck anyway for other reasons.
FAQs: Best Blank Discs Best TBCs Best VCRs for capture Restore VHS -
Never a problem whatsoever with ffmpeggui...It wont hurt to give it a try. I've made tons of DVD's using this program. No loudness issues and no compatibility issues at all. Go ahead and burn money on Vegas if you want.
ffmpeggui is not 100% compliant on for all dvd players. I have the samsung HD931 and absolutely hates that program as it causes all video to skip. I use the Sonic's SoftEncode to encode files to ac3 and have had no problems what so ever.Originally Posted by BJ_M
ffmpeggui is cheap trash IMO. -
Here you go:Originally Posted by BJ_M
http://www.svcd2dvd.com/test.ac3SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
it is not 100% compliant -- but very very close ..
this is what is reported:
SNR offset (fine SNR and fast gain code and channel fine offset) is incorrect or missing.
coupling strategy is missing (but may not be necessary) .
coupling leak - missing.
phase flag missing (but prob. not necessary on most player), but the yes it is in use or no it is not - is missing. ..
skip length is not used (missing) , it ussually is present. ...
anomaly: crc2 is same as sync word (well it is reported but i don't even know what that means - but it is not reported on a correct encode) ..
though this may sound like a great many things -- it is not (for example 75% of any commercial dvd's - when tested for video/audio/authoring compliant - do not pass) ..
but may be enough to cause some problems on some dvd players ... i can not positively say this is the case.
there are no gross errors though -- though if there was , usually the file would not play at all on anything."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
The AC3 TMPG plugin is Dolby Digital Compliant or else they could not display the DD logos with the product.
pillfalls?
- two channel only
- licence validation via internet
$29US not $300 or $400 dollars.-----------------------------------------------------
There is a reason why God gave us one mouth and two ears!!! -
BJ_M,
understood, would you like a short TMPG AC3 file for the same test? I'm curious....
sureOriginally Posted by awlchu"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
I have 2 Apex DVD Players and they Hate the.ac3 by FFMPEGUI. It plays but it slows down and warbles. However, .mp2 by FFMPEGUI plays fine. Go fiigure. Just thought ya'll'd be interested.
Have fun stormin' the castle!
Rog -
burnman99, if you can tell me step by step what you are doing to ge your DVD's to play, I try authoring my own with TDA but I get no audio play back. I was told to try using mp2 or ac3 audio but I ws just curious how u went about authoring yours being that I own Apex players as well.
Father knows best. -
no
Although I have no experience with these "free" AC3 plug-ins, I have always read bad things about all of them, specially BeSweet;
In the initial days of DVD authoring, all AC3 tools were very expensive cause it was (is ?) necessary to pay high licensing fees to Dolby Laboratories;
So, let me add that Ulead has just released a $ 30 AC3 plug-in to its "Grammy award winner" Video Studio 8, although I haven't tried it yet, it might work P-R-O-P-E-R-L-Y, as Ulead use to make good things;
Also, I think it doesn't have any annoying on-line verification like TMPGEnc's stuff;
So, as a suggestion to everybody, spend $30 and get it, there might be a free trial available;
Scenarist has a built-in 5.1 encoder, you don't have to use it for authoring, you can launch the sw just to use its built-in encoder;
Zetti -
to get the sonic encoder - you have to buy the 30,000$ package
Maybe one of you guys knows what is causing my problem here:
https://www.videohelp.com/forum/viewtopic.php?t=227235Father knows best. -
dudeman, i author my videos with DVDAuthorGUI. I have encoded the video with both Quenc and Tmpgenc and the audio with ffmpegui. When i make .ac3 with ffmpegui, my apex players choke on them but you do get audio. when i convert to .mp2, they play just fine. I have not tried the Tmpg author program in a long time so can't really tell you how to use it. DVDAuthorGUI requires you to split an mpeg into audio & video, unless it's a .vob file, but otherwise, is fairly simple to use and free. I highly recommend it.
I am trying to write an advanced guide for it, and should have it in the fairly near future. Am going to try to convert to .ac3 with Besweet and see if it will play in may Apex players next. Will let you know the results.
Hope this helps.
Rog
DVD-compatible AC3 Encoder
By roflwaffle in forum AudioReplies: 2Last Post: 14th Apr 2011, 14:42 -
AC3 to WAV = Wav has no audio??
By RobV in forum AudioReplies: 5Last Post: 31st May 2010, 16:26 -
Converting WAV/MP3 to DVD-compatible sound file
By Erasmus in forum Authoring (DVD)Replies: 8Last Post: 6th Apr 2009, 22:41 -
mp2 & wav compatible DVD authorers?
By Bassquake in forum Authoring (DVD)Replies: 4Last Post: 2nd Feb 2009, 15:11 -
Vista 64bit compatible encoder
By tommcd64 in forum Video ConversionReplies: 2Last Post: 18th Feb 2008, 08:21
