I have recently got a digital video camera.
I thought putting family movies onto dvd would be a good thing.![]()
I only have one problem
No matter what resolution i record in, by the time i have got it onto dvd the picture is just a small pic (about half screen size)on the tv screen.
when i select wide screen (pal 16:9) the picture becomes tall but narrow,
When i select Pal full screen the picture is still narrow but not as tall.
I cant seem to get it to fill the screen
I dont mind what software i have to buy, i just want to get my holiday movies onto dvd in a format I can watch without a pair of binoculars
I need to finish it off in pal - full or wide screen
If anyone can help i would be very gratefull![]()
thanks in advance ................ Maloricsdad
it would help if you told us what tools you are using.
I have been using Vegas 4 & DVD architect 1
but recently upgraded to vegas 5 & DVD architect 2 -
I use Photoshop to crop/resize stills to the 720x480 DVD resolution (any photo editor will work though). They fill the screen @ 4:3 ratio. Are you using the video slide show setting? I've never used that, I just make a movie of stills and use transitions to dissolve one into the other. The viewer does not have an option to move from picture to picture. I control that because I try to make the pictures synch with music, sound effects, and sometime i stick a video clip in the show.
Your manual should tell you what resolution you need, if you don't have a manual for the programs you listed, they are downloadable at the Sony site for free.If it works, don't fix it. -
Edit for my post: 720x480 will give you 16:9 format. To do full screen, crop your pictures to 640x480, then resize to 720x480. Everyone will look fatter, but it will be right at 4:3 format.
video formatting/ picture size
By rocks911 in forum Video ConversionReplies: 4Last Post: 7th Dec 2011, 18:47 -
picture size difference after transcoding (TMPGenc 2.5)
By jakewoodblues in forum Video ConversionReplies: 12Last Post: 27th Apr 2010, 20:57 -
How to fit the large size picture to the smaller size for print?
By coody in forum ComputerReplies: 7Last Post: 1st Apr 2009, 08:46 -
Vista Media Center Live TV Picture Size
By jbartosh in forum Media Center PC / MediaCentersReplies: 4Last Post: 15th Aug 2008, 15:59 -
How to change picture size
By hilario in forum Video ConversionReplies: 18Last Post: 24th Mar 2008, 08:04
