I'm currently authoring a DVD using DVD-lab PRO. What I am trying to do is set up a couple of buttons in a foreign text, and have the foreign text disappear and it's english equivalent appear when the button is highlighted. I was lead to believe that I could do this with the option Invisibility Selected, but all that seems to do is make it so that the button just doesn't highlight in color. That, of course, makes no sense to me since if I wanted that to happen, I would just set all the colors the same on the color map.
Does anyone know if that is a potential bug in DVD-lab PRO, or possibly another way to perform said feat?
You need to use switched menus.
http://www.mediachance.com/dvdlab/tutorial/switchmenu.html -
Or you could render the menu with the English equivalent button under the one you have made invisible when selectedand the English version will be underneath it. It won't necessarily be a button at this point, as it will be a part of the background but I don't think you or anyone else will be able to tell, if the buttons are the same dimensions.Originally Posted by bullet_ballet
Did that make any sense?Your miserable life is not worth the reversal of a Custer decision.
Menu button won't highlight
By mattblack in forum Authoring (DVD)Replies: 3Last Post: 21st Oct 2010, 18:45 -
DvdAuthorGui menu Button
By sambat in forum Authoring (DVD)Replies: 7Last Post: 15th Mar 2010, 08:04 -
Menu button for DVD Labpro 2
By warresg in forum DVD RippingReplies: 1Last Post: 13th Jul 2008, 10:37 -
Menu highlights disappear after tracks are played?
By Adam Bolt in forum MacReplies: 0Last Post: 8th Jul 2007, 16:52 -
question about dvd menu button
By HDMI in forum Authoring (DVD)Replies: 5Last Post: 23rd Jun 2007, 23:06
