When I try to open the .vdr file in TMPGEnc is says file unrecognized or unsupported.
Thoughts?
Hmm I finally figure it out, now Im getting another error. An Error Occured When ACM was Initialized.
Guess Ill do a search for that one on the forums![]()
Use Virtual Dub mod. Save the audio as wave. Use the wave file as input audio when frameserving.
Hello. -
Yeah I tried that. For some reason the audio gets the first few mins cut off it.
Probably has something to do with the fact that I cut some out of the video with VirtualDub before I started the whole process.
So the video starts at the same time the audio starts, but the audio is about 5 mins into it already.
Strange thing is, if I play just the .wav file by itself in Winamp, it starts at the correct spot.
The correct stuff got chopped out of both the audio and video, but now they wont sync.
No clue where to go from here heh.
Frameserving From VirtualDub to MainConcept
By hech54 in forum Video ConversionReplies: 0Last Post: 8th Mar 2012, 09:24 -
Problems re-using VirtualDub
By djdust in forum Newbie / General discussionsReplies: 17Last Post: 27th Apr 2011, 08:57 -
.mkv problems in Virtualdub
By alc112 in forum Video ConversionReplies: 14Last Post: 10th Feb 2010, 23:47 -
Problems with Virtualdub
By demonwarrior in forum Newbie / General discussionsReplies: 4Last Post: 8th Jun 2007, 09:23 -
A couple of VirtualDub problems.
By Rein Engel in forum Capturing and VCRReplies: 5Last Post: 1st Jun 2007, 03:07
