I authored a mini-DVD or DVD on CD for my wife’s boss. Then when I tested it it worked on my Liteon LVD-2001. However when I gave it to one of my friends to test it failed on all 3 of his DVD players. When I looked it up I realized that the mini-dvd has a very low compatibility rating. I am aiming for the best quality possible on a CD with a high compatibility for PC and DVD players while trying to keep media costs low.
Do CD(S) have a book type? If so - If I burned a min-DVD (DVD on cd) and set book type to DVD-rom would the compatibility increase?
I am aiming for compatibility for the non savvy pc user. So far I did a VCD but was hoping for better quality.
Mark
No, there's no bitsetting changer needed for CD-R's. But Mini-DVD don't have a high compatibility to DVD-players, but DO have a really high compatibility to PC! So, if I were you I'd buy a DVD+R(W) burner with a bitsetting changer! It may costs a bit but you do have a high compatibility!
Can you see what no one sees, through all the fake but showing me's? -
I have a lite-on 401S +RW with bitsetting firmware. The question I had is could I get away with bit setting and burning to a CD. If so would it how compatible would it be to DVD players then. I would try it myself by player can play mini-dvds so it would prove nothing. If there is a chance it would work then I would burn for my friend with 3 differant players to try.
Mark -
I have the same burner (LiteOn LDW-401s). I don't know what bitsetting utility you use, but mine (LiteON Booktype utility v.1.04) says "Not supported" when it detects a CD-R. I don't think it's possible to set booktype for Mini-DVDs. You can try to change booktype with Kprobe2, but I'd imagine you'd get the same results.
If God had intended us not to masturbate he would've made our arms shorter.
George Carlin -
Booktype can be only set for dvd+r/rw.
Mini DVD-R Samsung camcorder file type problem
By SASA39 in forum Video ConversionReplies: 4Last Post: 17th Jan 2009, 10:53 -
Can't change book type with Img Burn and Samsung 203N
By Vidikron in forum DVD & Blu-ray WritersReplies: 5Last Post: 2nd Apr 2008, 02:41 -
audio book to cd/dvd help
By breeze9 in forum AudioReplies: 1Last Post: 27th Jan 2008, 02:27 -
book type management
By MasterThomasMI in forum Newbie / General discussionsReplies: 5Last Post: 6th Sep 2007, 13:23 -
Pioneer DVR112 book type setting?
By tac7 in forum DVD & Blu-ray WritersReplies: 3Last Post: 26th May 2007, 16:02
