I'm using BETA 3 and doing a project with a VMG menu with two buttons that connect to two seperate import VTS sets with root menus. They connect to the menu fine but when I hit play movie it kicks me back to the VMG(title) menu. But if I select screen selections and start the movie from the first chapter it works. ??? Does anyone have any suggestions?
Thanks in advance.
Double check you conections and make sure they didn't get hosed up and are pointing back to the VMG menu.
sorry for the lateness of my reply, how do I edit the menu commands for an imported VTS, I thought they were set. If you know how I could edit and double check the commands for the imported menu's buttons that would be GREAT!!!!
Importing 3rd party VTS' into DVD Lab Pro can be a challenge. Unless you know the VTS is truly 'self-contained', this can be a problem for the user.
Who knows what register values must be set (to what value) in order for the import VTS to work.
Even in beta4 you cannot edit the imported VTS' VM commands.
This is not a short-coming of DVD Lab Pro, but the nature of importing a 'program' that you cannot change (its logic).-----------------------------------------------------
There is a reason why God gave us one mouth and two ears!!!
Some silent DVD menus won't work on Toshiba Blu-ray player
By denali in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 7th Feb 2012, 06:04 -
What can i do so imported videos in CS3 will work smoth ?
By eliqush in forum EditingReplies: 7Last Post: 22nd Feb 2010, 05:59 -
Motion Menus in DVDLab Pro question
By ArtOfLosingMFZB in forum Newbie / General discussionsReplies: 1Last Post: 8th Mar 2009, 16:47 -
How can i do switched menus with videos in Dvdlab pro?
By wan2no in forum Newbie / General discussionsReplies: 1Last Post: 25th Jan 2009, 23:54 -
m2t files won't work in Vegas Pro 8
By Patokid in forum Newbie / General discussionsReplies: 12Last Post: 21st Jan 2009, 14:47
