Hi guys... this is my first post so go easy on me.
I have been happily converting mpeg / avi etc files with stereo and ac3 for a while now using virtualdub and tmpge ready to burn to dvd. However, I have got hold of an avi with DTS audio and although I can play it on my PC using power dvd I cannot for the life of me decode the audio so I can carry on as normal and turn it into a DVD.
To sum up I need to...
1) strip the DTS audio out of the avi file
2) convert the DTS audio into ac3 or a format I can use.
The finished streams will be put through TMPGE as normal.
Any advice welcome and recommendations for software that will do the job even more welcome.
Cheers
Poindexter
P.S Ive collected various programs that may do the job (HyperCube / Oagmachine) but no joy as yet.
Results 1 to 1 of 1
Picking a Capture Card chipset, going in circles..
By LukeS in forum Capturing and VCRReplies: 22Last Post: 21st Oct 2011, 07:21 -
eac3to with HdBr Stream Extractor Decoding DTS-HDMA?
By MACCA350 in forum Blu-ray RippingReplies: 8Last Post: 17th Aug 2011, 00:01 -
"Upside down converter you turning me, inside out and round and round
By Blå_Mocka in forum Video ConversionReplies: 2Last Post: 18th Feb 2008, 12:23 -
DTS Decoding
By Neutral-Sage in forum AudioReplies: 8Last Post: 17th Nov 2007, 02:16 -
No sound..."feature missing: DTS Decoding" ?
By vm711 in forum DVD RippingReplies: 2Last Post: 15th May 2007, 16:59
