Does anyone know a way to equilize volume of .mpa files before burning a DVD? I created a movie with lots of cuts in Premiere and after I authored it in DVD-Lab I noticed the audio was too loud in some areas and too soft in others. It would be a lot easier to equilize the volume with some tool the way WinAmp does converting MP3s to WAV rather than adjusting the sound through Premiere by ear. Any ideas?
You might try "MP3Gain" (do a google search). It's freeware. Only drawback is that you have to first convert to MP3, then equilize, and finally re-convert back to either WAV or MP2. Other than that, it works pretty well.
wwaag
How does one process mpa and mpv files?
By mysts in forum Authoring (DVD)Replies: 2Last Post: 11th May 2011, 13:30 -
Is there a way to make all my .avi files the same volume?
By cyberax in forum AudioReplies: 3Last Post: 23rd Apr 2011, 07:35 -
Same volume for several video files!
By martinjamming in forum Newbie / General discussionsReplies: 4Last Post: 29th Jan 2010, 19:16 -
Merging MPA video and MP2 audio files
By makf in forum Newbie / General discussionsReplies: 2Last Post: 7th Jul 2009, 19:13 -
Low volume on flv files
By drwho in forum Video ConversionReplies: 3Last Post: 22nd Jul 2007, 17:13
