i have tryed several different programs to make a copy of "win a date with tad hamilton" and it WIL NOT WORK! This is the only disc i have ever waisted 6 friggin dvdr's on. I tryed xcopy express,simple and advanced,intervideo,clone dvd, and dvd-cloner, and none of them work. It burns successfully but when i try to play it it skips the whole way through like its in fast forward. Also ive tryed 2 different copies of the original and both with the same results. Any help would be great. Thanks
i backed it up for my sister the other day using dvd shrink and it worked perfectly. i suggest you try dvd shrink, its all i ever use and ive never had a problem with it.
btw, what kind of media are you using? this could also be the prob. -
I used HP, Sony, and some other brands. I guess i will waste one more disc and try dvd shrink. Thanks ill try it now and see what happens.
I dont believe it ,but it worked! Quality is not as good as dvd xpress,but its pretty damn close. Thanks alot man!! Ive done over 250 movies and never had this problem. LOL
prob joining VOBs; also sync prob with another movie
By spiritgumm in forum EditingReplies: 5Last Post: 19th Jun 2010, 10:32 -
A hardware prob, but what?
By ahhaa in forum ComputerReplies: 3Last Post: 22nd Sep 2009, 22:00 -
DVDs on hard drive for back up and play back on TV
By yadoc in forum Video ConversionReplies: 2Last Post: 2nd May 2008, 21:03 -
gc prob
By Mr anderson in forum ComputerReplies: 6Last Post: 10th Sep 2007, 06:33 -
MPEG DV prob
By mainegate in forum ffmpegX general discussionReplies: 0Last Post: 24th Aug 2007, 18:01
