Hi,
When im converting from AVI to VCD using TMPGEnc, the audio does not work.
I've extracted the audio to WAV and use taht as a source, but when i preview it, the audio doesnt work.
I've set my environment setting->plugin->directshow to 2 and its on top of the list.
how do i fix this?
thanx
You don't. Remember, it's preview, prelisten.
Anyway, if audio is such a big part of the preview process, suggest you only encode a portion of the video file, then if it meets your specs then encode the entire file.
Hello.
Video lags, drags, stutters when previewing in Adobe Premiere Elements...
By Captain Satellite in forum Newbie / General discussionsReplies: 3Last Post: 15th Mar 2010, 08:13 -
Suggestion for good software for previewing capture?
By The Kitchen Sink in forum Capturing and VCRReplies: 3Last Post: 26th Aug 2009, 09:26 -
No audio in TMPGEnc
By jay_lubb in forum Newbie / General discussionsReplies: 1Last Post: 19th Mar 2009, 02:26 -
Previewing and adding subs
By lucho89 in forum ffmpegX general discussionReplies: 1Last Post: 2nd Aug 2008, 07:28 -
Error after Previewing video + font problem
By ayamefan13 in forum ffmpegX general discussionReplies: 9Last Post: 9th Feb 2008, 18:30
