  1. In DVD-lab you can make an object invisible until it is highlighted, but when highlighted it makes it the color of the selected color in the map properties, is there a way to have it show up as its true image and color? Thanks
  2. The highlight is a subpicture limited to 4 colours (as per the DVD standard, it's not a limitation specific to DVD-Lab). You need to use switched menus to achieve what you want. The DVD-Lab web site explains you how this can be done. I sent you the link in your previous post.
