Hi
How can I remove frame from a video file?
Virtual dub removes frames one by one,so it is very difficult.
Help me please
I'd personally take the easy way out and use Adobe Premiere 6 to do it. That program is just the greatest! If I had the money, I would buy it! All you do there is load your movie into the project, zoom in so the timeline is displayed frame by frame, then razor the film to shreds and delete what you don't want.
irc.webmaster.com port 6667 #DDR -
If you are putting the movie on vcd... then I would suggest first encoding the file to mpeg, using TMPGEnc then use the Mpeg Tools portion of the program to edi tout the portions you don't want! Good luck!
:-p
Virtualdub VCR capture no dropped frames but 5400 inserted frames in 1 hour
By suloku in forum Capturing and VCRReplies: 12Last Post: 17th Aug 2011, 22:33 -
need help unblending previously blended frames rather than dropping frames
By BilboFett in forum Video ConversionReplies: 15Last Post: 12th May 2011, 21:15 -
Removing Weighted Prediction in P-frames
By ad.vid in forum Blu-ray RippingReplies: 4Last Post: 29th Oct 2010, 12:18 -
Removing Video Frames Damaged by Flash Photography
By SCDVD in forum EditingReplies: 8Last Post: 20th Mar 2009, 17:35 -
inserted frames without dropped frames in VirtualDub capturing VHS
By whschlebaum in forum Capturing and VCRReplies: 0Last Post: 23rd Aug 2007, 20:59
