I've seen people do this but when attempting to clip a video, and the export the frames with vdub into bmps, and the putting the bmps into animation shop and running it, its kind of delayed, it doesn't flow like it should..Ive tried setting the delay to 0 and its still jerky, it looks fine in the preview window for animation shop, but any other program, imageready included, shows that even with no delay it still lags..anyone know how to do a more successful clipping?
Hi,
i use to use QuickTime, just open the file you want turned into GIF and then from the file menu, select export.
select option and then from the drop down list select the option of GIF!
and then once you have confirmed it, wait for quicktime to stream it out into GIF!
another alternate software GIF Movie Maker, there was another one by ulead although i cant remember the name; maybe it was ulead gif factory???
im sorry but i cant remember the name for that software!
best of luck, AdamFor Queen and Country!!! -
GIF isn't an option on mine, I'm using quicktime 6.5, what version are you using?
hi,
my version of quicktime is 6.5.1 (UK Version)!
with version 5 there use to be a movie to gif option but with 6.5.1; you have to select export from the file menu. then set the export option to "movie to picture", from the use option below export, select "GIF"!
i know that some versions of quicktime do not have the GIF option (this depends on the installation type, the update components selected and the codecs installed); why dont you download a free trial of GIF movie gear from this website:
http://www.gamani.com/
hope that helps!For Queen and Country!!! -
I think I remember seeing an option on "Herosoft video converter" to convert avi to gif in one step.
YouTube clip -> animated gif
By raz1337 in forum Video ConversionReplies: 2Last Post: 8th Oct 2010, 23:14 -
Insert animated gif in movie clip - avi, swf or else
By wilderwildness in forum Newbie / General discussionsReplies: 1Last Post: 4th May 2010, 09:45 -
AVI Video Clip Without Audio
By jdvideo in forum Newbie / General discussionsReplies: 3Last Post: 26th Sep 2008, 16:03 -
AVI to animated GIF
By snafubaby in forum Video ConversionReplies: 10Last Post: 12th Nov 2007, 23:33 -
convert AVI to GIF
By ecos in forum Newbie / General discussionsReplies: 1Last Post: 18th Jul 2007, 12:17
