hi guys, i just wanna know if i've got the process right. i have avi files that i want to burn to dvd-r. so first i have to convert the avi files to mpeg2, then i use an authoring tool to burn to dvd. is that correct? also is authoring the same as burning?![]()
Kat
Pretty much. Remember, when you convert to MPEG, you must convert to DVD MPEG-2 before authoring. The specifications are in theOriginally Posted by katdabomb
What is =>DVD section at left. Then you author the MPEG file. This converts it to IFOs, BUPs, and VOBs files that you then burn to your DVD disk with your burner software.Hello. -
Before making a start on the full process which can be lengthy depending on your system and the final quality try Gspots software which gives the full info about the avi your going to encode, it will show up any codec problems and which format the avi is making it easier to alter any settings on your encoder, nothing worse spending a day encoding,authoring and burning to find the output film won't play.
Thats if you don't have it already
http://www.headbands.com/gspot/ -
The best thing i have found is Bullet Proof Softwares Video Converter and Decompiler.
WWW.bulletproofsoft.com
Its convert it, then author it in a DVD-Lab or such like...
How can I batch process AVI files and overwrite the originals? Please help!
By DrivesALot in forum Video ConversionReplies: 5Last Post: 21st Oct 2011, 20:59 -
DVD/vob/mpeg to Avi/xvid automated process, Help!
By sinz in forum Video ConversionReplies: 0Last Post: 14th Apr 2009, 01:08 -
What is a good xvid, avi cutter (for unwanted commercials) w/batch process?
By kbal in forum Video ConversionReplies: 5Last Post: 20th Dec 2007, 10:34 -
AVI to DVD process
By Vipero00 in forum Authoring (DVD)Replies: 4Last Post: 26th Aug 2007, 01:44 -
AVI Converting Process
By nkneedeep in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 20th Jun 2007, 15:27
