hi. i am trying to record a dvd movie to my vhs. i had connected all the necessary wires and can even watch the movie thru the vhs output monitor. when i press the REC button the image on the tv goes dark then goes back to normal then goes back to normal and so on. bottom line, the recording is not good. what could be wrong? dvd player output video problem? copyright issue?
thanks in advance for the help.![]()
Percy
It probably is a copyright issue. It sounds like Macrovision.
Hello. -
a copyright issue? does it mean that even if the the dvd is connected to my vhs and it would not record it properly? maybe you're right. thanks.
Percy -
The Macrovision function is periodically pushing the brightness level up and down in order to make the recorded output unwatchable. DVD players were made to do that as a form of copy protection.
"It's getting to the point now when I'm with you, I no longer want to have something stuck in my eye..." -
There are "Macrovision killers" available, along with the fact that some older VCRs can't see it. TBCs filter it out quite nicely. Camcorders with pass through have TBC circuits as well. So, in the end, Macrovision has outlived its usefulness.
Hello. -
thanks a lot for the information. i learned something again tonight.
tnx J316
Percy -
What you described is the effect of Macrovision. To eliminate this, first try the DVD Hacks page with the make and model of your player. If that fails, you can try either of these products listed below...
The VS-8000 Video Stabilizer removes copy protection when tranferring DVD or VHS to VHS only.
http://www.bgsales.com/shop/product_info.php/cPath/32_64/products_id/99?osCsid=0f78d3c...56adb2057dc894
The Clarifier removes all forms of copy protection when tranferring VHS and DVD in any direction.
http://www.facetvideo.com/xcart/customer/home.php
Problem recording onto VHS from AV2 - but DVD works normally - help please!
By Sassie in forum DVD & Blu-ray RecordersReplies: 0Last Post: 5th Jan 2010, 07:15 -
VHS to DVD conversion- capture is way too dark
By kzip in forum Capturing and VCRReplies: 11Last Post: 2nd May 2009, 21:39 -
dark and saturated image in SOME media players
By Persio809 in forum Newbie / General discussionsReplies: 2Last Post: 2nd May 2008, 14:48 -
DVD's no longer playing correctly on PC, image very dark
By tpham000 in forum ComputerReplies: 0Last Post: 4th Jan 2008, 09:50 -
VHS to DVD recording problem - strange line only shows up when viewed on PC
By CodySave in forum DVD & Blu-ray RecordersReplies: 11Last Post: 16th Jul 2007, 02:09
