I've had a hell of a time getting everything working up to this point, so ideally I don't want to update to FC2, but if I really need to, then maybe. Anyway, I've installed FC1 and MythTV on a spare PC with a PVR350 capture card in it, with the intention of making a PVR and stickin' it to the man (or, maybe its because TiVo isn't available in Canada) but now I have a problem. I need to get the video to be output on the DVI port rather than the VGA port. This will facilitate the watching of TV on my HDTV, which would be better than the Apple Studio Display thats sitting on my floor while I mess with settings. I've got pretty much everything figured out, I can make it use the 720p resolution, I can get the output to appear on the HDTV via the DVI port under Windows (and it works on with the DVI on my Mac too, but whatever) but now I can't figure out how to change the output to the DVI. I assume its something in my XF86Config file that needs to be altered, but I simply can't figure out what to do. Thanks in advance, as always.
Results 1 to 1 of 1
If it isn't broken, take it apart and find out why.
blog: deadsierra
Composite Output Problem with Nvidia Geforce 4 Ti
By Computer Nerd Kev in forum ComputerReplies: 24Last Post: 20th Aug 2011, 18:16 -
Black and White TV Output From Nvidia Geforce 8600 GTS
By nicolasqueen in forum Media Center PC / MediaCentersReplies: 7Last Post: 24th Jan 2010, 17:40 -
Computer DVI output to TV DVI input
By superdud1400 in forum DVB / IPTVReplies: 12Last Post: 13th Jul 2008, 09:44 -
Miro DC10 + Fedora core 8
By bmw524 in forum LinuxReplies: 5Last Post: 7th Jul 2008, 07:28 -
DVI output problem
By 1234567 in forum DVB / IPTVReplies: 35Last Post: 22nd Feb 2008, 12:11
