Ok, I'm beyond overwhelmed and confused.
I've decided to not get the ATI 9800 PRO AIW card. Newer graphic's cards are out with more memory (256mb), and are much cheaper. Unfortunately, they don't have the necessary inputs for analog capture and now i lose the ability to capture that way.
So now I'm looking for an internal capture device (possibly a TV-tuner card with video-in). The only problem is, I'm majorly confused. Its simple enough to capture the video, but how do you capture the audio? I'm assuming you run the red/white cables directly to my "Line-IN" on my soundcard, but how do you get the cables to fit? Do you need an adapter? Don't you lose the stereo sound (does the sound get turned into mono along the way)?
If someone could clarify this, I would really appreciate it.
Results 1 to 1 of 1
-mojo-
http://mpmediaproductions.tripod.com (old site with stuff)
http://www.mpmediaproductions.com (official site, being designed)
http://www.paulinasdesigns.com (current project)
video capture card advice
By MikeClark in forum Capturing and VCRReplies: 3Last Post: 10th Nov 2011, 22:10 -
Finding a Good Capture Card For An Xbox 360 System?
By LoC Blood Red in forum Capturing and VCRReplies: 14Last Post: 8th Sep 2010, 22:06 -
new system capture card analog and dv
By rikit in forum Capturing and VCRReplies: 0Last Post: 27th Nov 2007, 19:44 -
Which Capture card is best for my system?
By coolbyme in forum Capturing and VCRReplies: 12Last Post: 19th Sep 2007, 14:25 -
need advice on choosing a capture card
By specane in forum Capturing and VCRReplies: 3Last Post: 18th Jun 2007, 10:28
