I have some video clips that i want to put onto a dvd. Each clip i have is already converted into mpeg format. Now i know that a normal dvd holds like 4.35 gigs or something like that. But when i put the movies on.... it only can handle two files. Each file now that they are converted already is about 800mb. I should be able to fit more than just two files on a blank dvdr right? Well some one told me that i have to make chapters... and i could put more movies on a dvdr. Now dose that mean that i should take one of these movie clips ( one of the 800mb files ) and cut it into like 7 smaller peices, then burn it? Im using easy cd and dvd creator 6. It was packaged with my burner and has no instructions. What do i do here guys? Please help. I havent burned 1 dvd yet because i cant get everything to fit on a disk. The two 800mb files is to much for my disk!!
Thanks!!!!
