  1. hi all i got a problem still with tmpgenc plus
    i have power dvd install on my puter already and able to watch movies with power dvd 'yet when i try to convert an avi file to a mpeg-2
    file using
    tmpgnec i get this message
    you are trying to create a mpeg-2 file
    to playback mpeg2 file'dvd player software must be installed on your system
    mpeg-2 can not be played without such playback software
    like i said already i have powerdvd installed so why am i getting this message
    thanks all
  2. TMPGEnc doesn't check to see of you have PowerDVD, it simply warns that you need MPEG-2 decoder to playback MPEG-2 content.
    I have the same message (until i checked the box), and everything plays fine.
    Its a warning, not an error!
  3. thank you very much
    but which box do i need to check???????
  4. ok i checked the box
    now i'm getting
    read error occurred at address 00012f40 of module "tmpgenc.exe" with 47455049
    what is this????
    thxs again
  5. Originally Posted by cjbaby
    now i'm getting
    what is this????
    thxs again
    Now that one IS an error!
    Same link as jimmalenko:
    https://www.videohelp.com/tmpgenc.htm#problems
