Hey anyone having good capture results with the Radeon 64 Meg DDR card. mine look like crap, I was having nicer picture with an AIW 8 meg PCI by capturing to ATI VCR codec and converting to Mpeg with TMPEG..
Am I missing something... Perhaps the lack of Svideo in is causing this shitty capture on higher than 352x240, which is why I bought this card. Should I return it and get the Radeon AIW and suffer the graphics performance loss????
Any help/Advice is appreciated....
Regards
Mazrim Taim
Have the same card an I'm working on how to capture properly for VCD. I've changed the bit Rate and the pics were briliant but I cant write them to VCD so new plan. I've looked at "Capture" and Capture to ATIAW card and will try that.
Connecting the DDR and CD-Rom drives
By hellfire45 in forum ComputerReplies: 17Last Post: 4th Oct 2010, 02:57 -
Wanted: good/used DDR memory
By DirtBikeMike in forum ComputerReplies: 3Last Post: 9th Feb 2010, 13:54 -
DDR and DDR2
By Jomapil in forum ComputerReplies: 3Last Post: 18th Dec 2008, 07:50 -
DDR vs DDR2
By CSULB71 in forum ComputerReplies: 2Last Post: 1st Jun 2008, 14:54 -
DDR versue DDR2 Question
By SCDVD in forum ComputerReplies: 8Last Post: 11th Oct 2007, 13:50
