Hi, i have a 4 GIG iso, and when i want to burn it in nero it keeps coming back as
Invalid Block address
Could not perform DIsc-at-once
Any ideas what maybe the problem. I burn DVDS all the time. I have even tried to image the file so it acts as a DVD drive with the disc in!
Is there another program i should be using.
try from the original disk instead ...
when you mount it -- what happens ..?"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
DVD Decrypter ??
Click mode and select iso write , select your .iso file and hit the HD to Disc button.
Foreign Language Or Out of Sync Or Both!
By Westie69 in forum Blu-ray RippingReplies: 6Last Post: 8th Oct 2010, 07:35 -
Ripping Foreign Subtitles in my PC
By devilcoelhodog in forum SubtitleReplies: 3Last Post: 23rd Feb 2009, 10:28 -
How many 4.7 Gig DVDs may fit into 500 gig HDD?
By Bronx in forum ComputerReplies: 11Last Post: 24th Apr 2008, 10:40 -
newbie help for foreign subs
By A-thru-Z in forum SubtitleReplies: 1Last Post: 19th May 2007, 09:29 -
filename with foreign characters
By namsilat in forum Newbie / General discussionsReplies: 8Last Post: 13th May 2007, 20:34
