    Nov 2001
    Hello, I made fast and furious into a vcd and nero had no problem with and said it was complaint. But when I put it in my Ps2 it didn't read it and same for my Toshiba DVD Player. Can anyone help me?
  2. Firstly, the PS2 doesn't play VCDs so it's not surprising that it didn't play.
    With your Toshiba DVD player, does it say explicitly on the front panel or in the user manual that it can read CD-R or CD-RW media? Many players do not, or do not do it well.
    Have you ever tried playing an audio CD on the same CD-R media on your Toshiba player?
    If this is your problem, you will have to experiment with different brands of media to find one that works. In these cases CD-RW often works better.
    Regards.
    Michael Tam
    w: Morsels of Evidence
