I have a AVI movie, playing theough my div X player, but I cannot here any sound. I know there is sound on the movie, but whatever I play I cannot here the sound. Tried Windows Media Player, Real Payer, Playa, Divx player etc. What other player could I try. My PC is 350 P2, 128 meg ram. Everyting else (other movies) play wuth sound ok.
Do I need a special codec? What do I do with the codec when I get it?
Thanks for any help.
John
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
How do you know that? Usually the problems are in the video. There should be NO problems for sound. Might be a software/hardware conflict? -
I have the same problem with a DivX, the movie plays fine in Media Player but in Virtual Dub theres no Audio!
/Lars -
I was having the same problem. I think I've found the solution. You have to use VirtualDub to save the audio file in the avi to a wav (there are explicit instructions here in the HOW TO: CONVERT section). Then use that file when you load your project into tmpg.
Hope that helps!
Liz -
Well, if Virtual Dub can't find the Audio how can you then save it into a wave?
I solved my problem by installeing Adobe premiere 6.0, Vegas Video 2.0b and Direct X 8a, I have no idea whaich of these that gave me the right audio codec but I got it from one of them... and now it works. I was lacking the "MPEG Layer 3 Codec (professional)" codec and I think it came from Vegas Video .20
Thanx/
Lars
Editing AVI movie with avidemux resulted in distorted sound. What can I do?
By johnharlin in forum EditingReplies: 2Last Post: 29th Jul 2011, 16:49 -
No sound when converting muxed mpeg-1 file to AVI DivX!
By mute82 in forum ffmpegX general discussionReplies: 5Last Post: 25th Oct 2007, 12:56 -
no sound on my avi movie
By hardtime in forum Newbie / General discussionsReplies: 5Last Post: 21st Oct 2007, 22:28 -
MPEG-1 to AVI DivX: No sound
By Waterman II in forum MacReplies: 0Last Post: 18th Sep 2007, 03:16 -
No sound when converting FLZ file to AVI DivX!
By zanyjudy in forum ffmpegX general discussionReplies: 3Last Post: 14th Sep 2007, 06:02
