Results 1 to 24 of 24
  1. Member golfnut's Avatar
    Sep 2003
    Is there a simple program that anyone knows of for making your own custom DVD covers? I have tried Adobe Photo but just too complicated of a program for this simple mind of mine. Any suggestions would be greatly appreciated or a detailed step by step guide would even be better if anyone know of one. Thanks a million for your help and time. Have a great day.
    Thank You,
    GolfNut
  2. i'm afraid that there is no simple way to make custom covers. the two programs used the most are PSP and PHOTOSHOP. both are difficult programs to use.
    and when you are able to use those programs, get ready for an even harder task....finding good COVER ART!!!
    the only suggestion i can make is to check out DVD COVERART. But they are currently in some sort of legal battle. But I would recommend saving that link! It's one of my favorites sites out there!
  3. Member golfnut's Avatar
    Sep 2003
    flyerstothecup thank you for the reply, I was afraid that would be the case. Have a nice weekend.
    Thank You,
    GolfNut
  4. Member tekkieman's Avatar
    Mar 2004
    Over the hill
    I'm afraid I would have to disagree. I make all my covers with the software from my label program. I use Mediaface II software, and buy the full case labels at 20 for $9.00. It will accept most image types, has art text, regular text, etc...
    The software is also free to download from the NEATO website.
    http://www.neato.com/neato_prodtest_download.asp?class%5Fid=%5FDOWNLOADS&cat=%5FSOFTWA...5QXD3K3VKF6LE4
    You have to register, but the II version of the software is free. They also have templates for Photoshop.
    Mar 2003
    Las Vegas, NV
    Try SureThing CD labeler. Lets you make all the custom DVD covers you want.
    Burn Baby Burn
    It's a Disk-o Inferno
  6. Member golfnut's Avatar
    Sep 2003
    tekkieman, thank you for the reply. I am speaking of the DVD covers which slide into plastic holder on dvd cases, not the disc label, do you mean the covers or the disc label? Just wanted to clarify. Thank you.
    Thank You,
    GolfNut
  7. Member tekkieman's Avatar
    Mar 2004
    Over the hill
    Full plastic case insert covers. Just like you get when you buy a retail DVD. NOT DVD lables. This week at Staples, they have the plastic cases 25 for $9.00, another $9.00 for the DVD inserts, and a lot of ink for the printer!
    While DVDCOVERTART.COM may be down, and there is another thread going about one of the other cover art sites and spyware, there is another site I use for cover art, I just don't have the link right now. I'll get the link tonight and post it for you, or just search the forum for cover art.
    And before someone else points it out, you could always just scan the ORIGINAL cover of your LEGALLY purchased movie!
  8. Thanks for the heads up on the other means of cover art.
    However, i still would have to see something made from one of those other programs before i'd give it kudos!
    and the reason for CUSTOM covers isn't only for those that may burn backups. but also, to replace cover art that is just plain bad! case in point....MATRIX: REVOLUTIONS! could they have made a worse cover?
  9. Member golfnut's Avatar
    Sep 2003
    tekkieman thanks for the clarification, 9.00 seems very high for 20 covers though, can you use regular 8.5x11 photo paper? Thanks again.
    Thank You,
    GolfNut
  10. Member golfnut's Avatar
    Sep 2003
    Popee thanks for the recommendation, I will give it a try. Any guides to how to use surething?
    Thank You,
    GolfNut
  11. Member tekkieman's Avatar
    Mar 2004
    Over the hill
    Sure, you could use toilet paper if you wanted to. I just use the covers from the software manufacturer because..
    a) they're thicker than normal paper
    b) they're perforated and a perfect fit to the case
    c) no alignment problems (they're longer than 8.5x11)
    You can find posts here suggesting using legal size or A4 paper for covers. Normal 8.5x11 has some edge printing issues.
  12. Member golfnut's Avatar
    Sep 2003
    tekkieman thanks again, will definitely try your method. Have a great day and by the way I doubt toilet paper would work too well, may be a little on the thin side. LOL.
    Thank You,
    GolfNut
  13. Member tekkieman's Avatar
    Mar 2004
    Over the hill
    Should have clarified...2-ply!
  14. Member golfnut's Avatar
    Sep 2003
    Right, that should work much better, have a great weekend.
    Thank You,
    GolfNut
  15. hey tekkie,
    you happen to have a link to a dvd cover you made with your the mediaface software? i'm curious to see a finished product.
    thanks.
  16. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    I found a .jpg on the internet of the outline of a DVD cover(exact dimensions) that I open with Microsoft Image Composer...then I put my artwork or simple text over top of that .jpg....then I print it with a program called Multicoverprint and A4 paper.
    Here's a shrunk down sample:
  17. Member tekkieman's Avatar
    Mar 2004
    Over the hill
    hey tekkie,
    thanks.
    Not at work, no. I can put one up for you later, maybe this weekend. They're nothing special, just copy the large image from the site, slap it in the template, and resize. Once resized, the image degrades, but I'm not really looking for perfection, or even original. Just something to identify it on the shelf...
    Got the site link from this thread....
    https://www.videohelp.com/forum/viewtopic.php?t=204092&highlight=cover+art
  18. Originally Posted by hech54
    that's not the issue i'm speaking of. i know that you can put SIMPLE TEXT and PICTURES on piece of paper. but can you do the necessary editing to make it the quality of a store bought insert? alot of the text used on the back of DVDs wouldn't fall under "simple text" in my mind.
    I just want to see what you guys are calling a quality cover. the reason i use PSP is because i want the look of a regular DVD case, but with different art, etc. not just a collage of picutures with a big banner with the movie name.
  19. Originally Posted by tekkieman
    ...Once resized, the image degrades, but I'm not really looking for perfection, or even original. Just something to identify it on the shelf...
    DING DING DING!!! there's the answer i was looking for! :P
    From Golfnuts post, I see that he may not be looking for the quality that I look for when making covers. And the fact that he said he wasn't fluent with PSP or PHOTOSHOP. So the ideas you guys came up with may be perfect for him.
    Good luck with your project Golfnut.
  20. Member tekkieman's Avatar
    Mar 2004
    Over the hill
    Not from me, I never used the word quality for what I'm doing. I make simple duplicate covers for my backups so I can find them on the shelf. Nothing more.
    All I was telling golfnut was that the software I use will take almost any image, has some minor editing features, and if everything stays within the dotted lines (literally), you can print a cover that fits the case, with the proper dimensions, and the spine in the right place.
  21. I use the multiflip inserts from Rima.com and get excellent results. I believe I paid $12 for a 100 Pack last time. Never gotten better prints on any insert paper before.
    I use a combination of Photoshop and Ulead Photo Impact. PI is a lot easier program than PS but its also got some pretty good features. It runs about $80 retail. If you want a sample there is a high quality sample up a cdcovers.cc that I made with it. I don't think I can direct link to it the way their site is set up. just use the search box to search Playstation games for Dragon Warrior. Its listed as a custom cover for Dragon Warrior 7. Its a DVD size cover. You can also find some good cover art at that site as well.
  22. Member golfnut's Avatar
    Sep 2003
    Thanks a million to everyone. I think I have enough suggestions to keep me busy this weekend trying to see if my simple mind can comprehend your recommendations. Have a great weekend guys.
    Thank You,
    GolfNut
  23. Member p_l's Avatar
    Montreal, Canada
    Another quick and easy way is to use the Nero Cover Designer that comes with Nero. If you have Nero installed, you have it. Look under Start | All Programs | Ahead Nero | Nero Cover Designer.
    Just remember to use Legal (or A4?) paper and set it to Landscape.
  24. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    I think my cover is "BEE YOU TEE FULL"...and besides...it's only for my enjoyment anyway. The fact that I took a production VHS tape - put it to a DVD - placed chapter markers between the songs and made a menu to access the individual songs is what is most important to me.
    If it's quality you want...scan your original DVD Cover at 300dpi or higher then print with Multicoverprint to make sure it is the correct size.
