Hope someone can help me out on this. I tried converting a DivX (half screen) video to VCD using tmpgenc, but after converting the video the output is having large pixels. Is there anyway I can convert the video having the same quality as the source? Also, do I need another software to convert the file or is tmpgenc enough already. Suggestions are very welcome. Thanks.
JP
Originally Posted by jcosido -
When you used TMPGEnc, did you select a VCD template? Also, was the bad product on a disk, or was displaying artifacts on your software player? Also, did you know when you post you should post as much information as possible, so that you return are not filled with as many quaestions as your original post, like this one?
Hello. -
Sorry about my post. I'll try to give you more information about it.
@abond: Half screen meaning not Full screen. Meaning the video is only occupying the center part of the screen. Is there a correct term on that? Please enlighten me. Thanks.
@Tommyknocker: Yes, I did select the VCD template. The finished product displayed some big pixels on the screen. Is there any way to improve the output on this?
Your help is highly appreciated.JP
Quicktime parse error converting mpeg-1 muxed to DV or mpeg 4
By jglass in forum Newbie / General discussionsReplies: 0Last Post: 15th Jun 2008, 20:51 -
Converting Divx w/ Vorbis audio to Divx w/ MP3
By tachyon2u in forum AudioReplies: 3Last Post: 23rd Feb 2008, 23:35 -
problem converting mpeg 1 to divx
By goingape in forum Video ConversionReplies: 11Last Post: 9th Jan 2008, 14:17 -
Converting HD (DivX/MOV/WMV etc) to DVD or DivX ???
By snadge in forum Video ConversionReplies: 32Last Post: 8th Jan 2008, 05:48 -
No sound when converting muxed mpeg-1 file to AVI DivX!
By mute82 in forum ffmpegX general discussionReplies: 5Last Post: 25th Oct 2007, 12:56
