Even with two films, the VIDEO_TS folder that is created doesn't exceed 2.5gig - it's not worth burnin that too a dvd when so much space is being wasted. Am I missing an option somewhere that tells the program to use a whole dvd?
try putting 3 or maybee 4 films on then. it depends on the size of the film
regards phil -
yep...all depends on the original files sizes....
pretty much...i dont know the exact formula...but add 100 mbs to your current video file...and that is the finished product.
So say you have 4 files...at 700 mb each....thats....ummmm
/me pulls out his calculatory system
2.8 gb....add 400 mb.......thats 3.2...add 100 mb for OTHER ....and your dvd is gonna be around 3.3 gb big...
just go with adding 100mb to each file...then add 100mb for menu/other
and you should be able to get a rough estimate of the size your resultant DVD will be.
Cheers
Right, thanks for those replies. I wondered at first if it meant that the quality was being reduced. It makes sense now, cheers.
why can't I produce an ISO from a multisession track DVD ?
By Bansaw in forum Newbie / General discussionsReplies: 5Last Post: 20th Dec 2010, 11:43 -
NERO Vision Won't Produce DVD's
By Ensign in forum DVD RippingReplies: 11Last Post: 29th Sep 2009, 11:43 -
Produce DVD with chapters, menu etc
By tempsc in forum Newbie / General discussionsReplies: 2Last Post: 21st Apr 2008, 10:10 -
SVCD2DVD won't not turn off computer when it is done.
By vn1 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 11th Dec 2007, 04:59 -
SVCD2DVD won't launch on my XP laptop
By geek2330 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 6th Oct 2007, 10:29
