I backed up some films using dvd decrypter and dvd shrink and Ritek dvd+r 4x. They worked fine on both my Toshiba players, sd4900 and svc391. Then I backed up some dvd-r to the same media, Ritek 4x dvd+r, using only dvddecrypter. It plays on my 4900, but not on my 391.
Why would that happen? It must be either the burning process or the dvd-r that i am backing up.
It could be a bad piece of media. It could be...
Well, you're getting us a bit confused, for one thing, by using the term DVD-R to describe what you're burning, and then saying that you're using DVD+R media.
but at any rate, it's possible that DVD Decrypter just had a bad day, or perhaps that one of your players doesn't like DVD Decrypter's burns. It's tough to say.
Try it again, burn at a lower speed while not doing anything, see if that makes any difference.
- Gurm -
Well, the media from which I copied is a dvd-r 4x speed . The media to which I copied is a dvd+r 4x speed.Originally Posted by Gurm
I tried it again burning one at onex speed and it still didn't work on my vc391. -
There's something the DVD player can't read as a result of burning from an ISO. Try a conventional file mode rip and burn with Nero or Deep Burner.
I downloaded deep burner, but can't figure out what to do with it. what is a conventional file mode rip and burnand how do I do it with deep burner?Originally Posted by wulf109
I often notice my software having bad days for no apparent reasonOriginally Posted by Gurm
Buslink Model DVRW412RQOriginally Posted by handyguy
When I try to use those disks that don't work in my vc391, it says incorrect disc
Dennis
question about dvd shrink
By marlo in forum Authoring (DVD)Replies: 5Last Post: 29th Aug 2010, 05:22 -
Hello I'm New & I Have A Question About DVD Shrink 3.2
By taffy1967 in forum Newbie / General discussionsReplies: 3Last Post: 4th May 2010, 05:28 -
question about DVD Shrink
By Bamahusker in forum DVD RippingReplies: 7Last Post: 1st Mar 2010, 21:48 -
DVD Shrink and Nero Recode question.
By siratfus in forum DVD RippingReplies: 8Last Post: 13th Jan 2010, 22:49 -
question regarding analyze in DVD Shrink
By Bamahusker in forum Newbie / General discussionsReplies: 2Last Post: 8th Jul 2007, 09:31
