I would like to put some graphic presentations on a DVD, like presentations from PowerPoint. I have 20 presentations, each having 70-80 slides (static images).
I would like this DVD to contain a meniu with all this 20 presentations, and in each presentation I want to navigate through slides using Back and Forward buttons on my DVD Player Remote Control (I don't want my show to play automaticaly from a slide to next slide).
I am not interest to have sound or transitions between slides.
I saw a DVD like this and I know that is possible to make this type of DVD. If it helps, the structure of that DVD was like this: 20 titles, each title having 80 chapters; after DVD displays a slide, it goes automaticaly on Pause mode, waiting for me to press Back or Forward on Remote Control.
I tried to make a structure like that, but it plays automaticaly my slides. I could only turn back to meniu after a chapter is ended.
A solution can be to make loop on a chapter. I don't find a program that can do this.
Can you recommend me a program and some help to create this type of DVD?
Thank you.
Lorand SZEKELY
I tried Pinnacle Studio 8, Nero Vision, Photo2DVD, DVDSlideShow, PowerPoint2DVD and one program from Adobe (I forgot it's name) but this programs didn't help me to make that DVD. Or, may be I don't know how to set some parameters for my presentations (?)
At your sugestion I will try DVD Lab. I never used it. I hope it will help me.
If you have some other sugestions that will help me, please write it down here.
Thank you, very much.Lorand SZEKELY -
It is possible with dvdauthor, if you create your 'stillshow' as menus. AFAIRC you may use 99 titlesets with 99 submenus each. But you would need some scripting knowledge, as I don't know a GUI for that special purpose.
You may use my GUI for dvdauthor to test, but I have a limit of 99 submenus in total (may be I will change this sometimes...). Therefore it would be sufficient for 1 presentation only.
The next is the comfort: I think it is quite cumbersome to add each slide of your presentation manually...
How to add a DVD video to a Powerpoint Presentation
By andy jackson in forum Newbie / General discussionsReplies: 3Last Post: 17th Feb 2012, 13:27 -
how can i convert a powerpoint presentation and put it on dvd
By shashgo in forum Newbie / General discussionsReplies: 7Last Post: 8th Oct 2009, 04:14 -
Get Presentation Off DVD With A Menu...
By tomyknoker in forum ffmpegX general discussionReplies: 2Last Post: 24th Aug 2008, 06:13 -
Recording Video to DVD from PTZ Camera and Presentation on Monitors
By timotheus in forum Newbie / General discussionsReplies: 2Last Post: 14th Jul 2008, 01:48 -
Powerpoint Presentation to Video/DVD Software
By Nasho23 in forum Newbie / General discussionsReplies: 2Last Post: 11th Apr 2008, 00:59
